Radio static bad
Radio static bad
Just got back from vacation My car was dead so I jumped it , now all that comes out of my radio is static my xm and cd works fine.plus when I switch from each pre programmed stations there is the same song/static on each stations My auto shop couldn't figure out what it may be .is it a amp or the antenna receiver box located on the drivers died under a piece of molding ?. Please help
Not sure where you live since I'm on my phone but how cold is it where you are? It's freezing cold in most of the country and mine does that too but once the cabin gets warm it goes away. May or may not be your issue but just a thought
Thanks I'm in chicago I know it is hella cold outside. But it's been real cold and never had issue with my car warming up then working it always worked loo
Sounds like a radio receiver problem. Receivers are very sensitive to ground interference. If you have a radio sound quality problem where all other functions work well, I'd start looking at any ground point the ties back to the radio power source or antenna wiring. If not the ground, then check the capacitor on the radio ground connection. The capacitor is there to reduce transients in the antenna signal.
Is the capacitor the device that's located behind the panel,on the drivers side back . I got to the back of the radio and tested with another antenna, there was still static. Do you think its the radio or reciever that's bad??
4drviper
Apr 23, 2025 07:13 PM
dirleton
Aug 6, 2024 08:19 PM
SinCityTLX
20
Oct 19, 2015 11:23 AM
jdmaszfcuk
Oct 19, 2015 12:31 AM
