Radio setting?
Old May 9, 2006 | 09:59 AM
mjferguson's Avatar
Radio setting?
I have noticed that my presets get all screwed up (I think after my wife drives the car). Is there some sort of configurable setting that changes presets, etc. based on memory seat settings?
Old May 9, 2006 | 10:02 AM
AMIC's Avatar
Fightin' Texas Aggie
Yes each FOB has it's own set of presets. Make sure you always use the same FOB everytime you get in the car then your seat, mirrors, and presets will always be the same.
Old May 9, 2006 | 10:07 AM
mjferguson's Avatar
That is what I figured. I usually don't use the FOB in the morning, the car is in the garage. I thought it was strange that the acutal memory button inside the car does not seem to change the radio presets? Is this only triggered by the FOB?
Old May 9, 2006 | 11:58 AM
Will Y.'s Avatar
Registered but harmless
The key fobs control all presets. Otherwise, try hitting the appropriate memory preset button on the driver's door to see if that also controls the settings for the radio, climate control, etc. I haven't tried this yet, as my wife and I use our own fobs.
Old May 9, 2006 | 12:03 PM
mjferguson's Avatar
I tried the memory preset button and it doesn't seem to control these settings. Kind of strange since the FOB does. I guess I will just have to hit the unlock on the FOB even when my car is sitting in the garage unlocked? Doesn't make much sense that the presets on the door wouldn't do the same thing?
Old May 9, 2006 | 02:47 PM
AMIC's Avatar
The door button does not control the presets just the seat and mirrors.
Old May 9, 2006 | 04:12 PM
acuraTL44's Avatar
The memory buttons do control radio presets and climate control, u just have to press them before the car is started. Once the climate control and radio presets are loaded, u cant change them until u restart the car, unlike the rest of the settings, which can be changed while the car is on.
and you need to lock the car, in order to change between driver 1&2 w/the fobs
rockyboy
Aug 4, 2024 10:35 AM
johnalfa
Oct 31, 2015 12:55 PM
Birdflunuggetz
ILX
Sep 14, 2015 07:00 AM
braveheart
Sep 7, 2015 08:12 AM
iRaw
ILX
Sep 5, 2015 12:10 AM
