Radio setting?
Radio setting?
I have noticed that my presets get all screwed up (I think after my wife drives the car). Is there some sort of configurable setting that changes presets, etc. based on memory seat settings?
Fightin' Texas Aggie
Yes each FOB has it's own set of presets. Make sure you always use the same FOB everytime you get in the car then your seat, mirrors, and presets will always be the same.
That is what I figured. I usually don't use the FOB in the morning, the car is in the garage. I thought it was strange that the acutal memory button inside the car does not seem to change the radio presets? Is this only triggered by the FOB?
Registered but harmless
Received 1,102 Likes
The key fobs control all presets. Otherwise, try hitting the appropriate memory preset button on the driver's door to see if that also controls the settings for the radio, climate control, etc. I haven't tried this yet, as my wife and I use our own fobs.
I tried the memory preset button and it doesn't seem to control these settings. Kind of strange since the FOB does. I guess I will just have to hit the unlock on the FOB even when my car is sitting in the garage unlocked? Doesn't make much sense that the presets on the door wouldn't do the same thing?
The memory buttons do control radio presets and climate control, u just have to press them before the car is started. Once the climate control and radio presets are loaded, u cant change them until u restart the car, unlike the rest of the settings, which can be changed while the car is on.
and you need to lock the car, in order to change between driver 1&2 w/the fobs
rockyboy
12-06-2022 02:29 PM
braveheart
09-07-2015 08:12 AM
