radio dies out PLEASE HELP
i am installing subs in my car . all the wires are run ( all brand new wires connections etc ) brand new amp and new subs/ box , jl audios
problem is when i start the project i take power off the battery ofcourse so i DONT blow anything wire everything up run it to my trunk and plug everytrhing back in then put power back on the battery , i start my car / turn it on my radio DOESNT WORK , lights up and the ac / heat works and is visible , but radio in no way shape or form works
i had this happen to me be4 and tweeter fixed it for me saying it was just a blown fuse, problem is i checked ALL my fuses and the radio fuse itself the bottom left fuse panel under drive side and all were fine , is this something that has happend to some1 else OR does any1 kno if there are any other fuses that are attached the radio that would bemaking this happen PLEASSSSEEE HELLP ME!
remove the battery cable again for 30 minutes and put back on. Then it will ask you for the security code, if you do not have it, you must go to the dealer and get it. After that, all should be good.
ive actually removed the battery a few times for more then 30 seconds i mean i was playing with wires as that was done, i will try thatto see if it works of course any1 else chime in on this? , thank u for ur reply!/help
the radio will reset and ask for a code if power is lost for over 30 seconds or something of the nature. Try seeing if it asks for a code after doing this.
yah sadly still did not work, took the radio out again after this checked the wires again still NOTHING , took it to tweeter still nothing any1 else have any suggestions or any help , again thank u for ur help
Just for clarification, the lights on the radio turn on with the headlights, but it does not turn on to give out audio, right?
Lets just clarify your setup:
1. Where did you get the signal for the subs?
2. Where did you get the trigger wire from?
3. Did you install anything other than the subs and the AMP, like speakers or new tweeters?
4. Is the factory AMP still there in the car?
5. Do you have a factory navigation system?
yes my factory amp is still therer all i did was run power wire from batt to trunk amp( aftermamarket one for subs) ground romote turn on from head unite ( NOT nav system ) the rcas from afteerr maarket box behind hea unit ( professionally installed ) and yes it all lights up when lights are on but NOTHING will work as far as radio but my heat and shit work. i did not install nething else at all ( tweeters and or speakers ) and again NOTHING comes up on the rdio ond wont work neathier the cd player or tape deck work but again all lights up ( sorry to put all in one paragraph im tyyping on my cell phone not ez to do ! ) thanks again guys
its that trigger wire you tapped into. If you hooked it up to the subs, then it's not sending the proper power for the other stuff to turn on.
dirleton
08-06-2024 08:19 PM
Puma Jim
20
10-20-2016 11:59 AM
MetalGearTypeS
08-29-2016 08:28 PM
SinCityTLX
20
10-19-2015 11:23 AM
jdmaszfcuk
10-19-2015 12:31 AM
