Radio Code Help
Old Oct 28, 2012 | 02:56 PM
07BLKTL's Avatar
Radio Code Help
So I have my radio code the 8 digit code. I can't get the code for the navigation though?
When I first start the car and have the warning screen show it asks for a 4 digit code?
Where can I get that?
My one hour ride to work tomorrow is really going to suck without my usual traffic/weather/news reports.
I know there are a bunch of threads on radio codes, people saying that you need to search your glove box/owners manual. And usually the code is there? I did and couldn't find it, but did find a thread explaining how to get the radio code?
What about the Nav?
Old Oct 28, 2012 | 03:26 PM
Noober's Avatar
Once you find the code for the radio itself, your navigation should work as well. It's normally inside one of the pockets of the owners manual. That or you can go to the dealership.
Old Oct 28, 2012 | 04:17 PM
07BLKTL's Avatar
Thanks, I'll search the manual and book and once again.
Old Oct 28, 2012 | 05:28 PM
Bada$$VTEC's Avatar
OMG-6SPD
On my 05,my radio code is 5 digits while navi is 4 digits.
If you just put your radio code i doubt you navi will be unlocked.
So for you to get your navi code you have to take out the trunk liner
by where the navi is & check for the serial number under the dvd unit.
Call the stealership & give them that serial number then they should give you the 4 digit code.
Old Oct 28, 2012 | 05:46 PM
Will Y.'s Avatar
Registered but harmless
FYI, the original navi and radio codes (they are separate codes, one is 4 digits and one is 5 digits) were printed on a plastic card the size of a business card and included with the paperwork for the car.
Owners sometimes put the code card in the owner's manual (there's also space for them to be written into the manual); some used car dealers put the code card in the spare tire compartment with the trunk nets.
Mechanics might have written the codes on stickers placed in the glove box or on top of the hood fuse box if the car was regularly serviced at a dealership.
You can also check to see if the car and codes are registered @ the Acura owner website @ http://owners.acura.com.
If all else fails, to get the codes by phone from a dealer, you'll need the serial number for the radio, but just the car's VIN for the Navi code.
G/L.
Bada$$VTEC's Avatar
OMG-6SPD
OR try this to see if it works while locked out..
Press Map,Menu & Cancel at the same time,you should have a diagnostics like screen pop up
Then press Unit Check,another screen should pop up then press Navi ECU
Its gonna display some stuffs,you should see your serial number & current version of the disc you're running
Old Oct 28, 2012 | 06:26 PM
nickn7's Avatar
my code is located on the outside of the glovebox (facing the driver seat) when you open it if that makes sense? It's engraved on a tag.
Old Oct 28, 2012 | 07:13 PM
07BLKTL's Avatar
G/L.
So, I found one code in the book, the bad part is It's only the 5 digit radio code
Tried to get the codes from my acura and it locked my vin number because it kept telling me the zip/vin/phone numbers were incorrect. No such luck finding the plastic card with the numbers on it anywhere.
Thanks, I tried this and didn't get anything guess it doesn't work when it's locked out.
Thanks, I'll go take another look, but I've not found it anywhere
Thanks for all the help everyone I didn't think this would be this hard!
Old Nov 13, 2020 | 02:35 PM
JFRENSH's Avatar
How to retrieve 4 digit Navi Code
Scrolling through the various threads on Acura Navi Codes and how to retrieve I found a sure fire method to retrieve your code. I have an '05 and '11 RL. Main display screen and trunk mounted Navi DVD reader failed. I obtained replacement screen and player from LQK salvage yard in Daytona Beach. Total cost $50 ($15 screen and ($35 drive).
Upon install I did not know 4 digit Navi Code. First obtain serial number off the trunk mount dvd player. Usually 3 letters and 8 digits. You can retrieve from bottom of unit or through the "not so secret menu" see related threads. Next, call Acura Customer Support and follow prompts to get to Navigation support. 800-382-2238.
When you reach a Representative explain the circumstances - in my case Navi player replacement. Rep asked for serial number and VIN of the vehicle in which the unit is now installed. BINGO. Simple and easy as pie.
Note: Don't reccomended calling Dealership. They will want an hour diagnostic fee.
Good Luck.
dirleton
Aug 6, 2024 08:19 PM
Jamus22
Jun 11, 2023 10:08 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
