Radio code
BANNED
no navi?
not really sure, mine popped up on the navi screen when i had to reset mine.
try disconnecting the battery, hooking it back up, and see if it pops up
I do not have the navi, but when I turn on the radio I believe it says "code" and I enter in my code with the numbered radio buttons. It then beeps and turns on the radio.
2004 Acura TL
i push the power button and it doesn't turn on.. the radio fuse is fine and i get no power to the radio. is there a fuse behind the radio?
BANNED
^theres the million dollar question...
BANNED
idk man that sounds unlikely.
what happened? you just started your car today and the radio didn't work?
have you done anything to your car recently?
2004 Acura TL
i just got it back from the shop after getting the axles changed. they had to jump it to get it started and i left and the radio wasn't working. bought a new battery and put in the navi code but still no power to the radio. it was working perfect before i brought it to the shop.. and also my ipod touch was stolen and the owner found it but came up with a story that didn't make sense. also when i got the car back all the cd's that were in the radio were taken out
okay......Heres a hard one for you to grasp...
go back to the shop. they fuxored your shit
2004 Acura TL
Egad man, you've had a host of problems...OK, did this happen before or after the turn signal problems? Have you done any other mods or electrical work to the car?
I assume the fuse you checked was fuse #5 in the under dash fuse box. Did you pull the fuse out and inspect it?
And what kind of back street shop did you take it to where they rip off your stuff? (Of course, there's a lesson to be learned from this experience).
Edit: Pull fuse #7 for one minute and then put it back in. Turn on the radio and see if the display reads "COdE".
2004 Acura TL
yes it was #5 (RADIO) and it wasn't blown but i still replaced it anyway.
i took it to a licensed shop in town
this happened before the turn signal problem.. the turn signal problem happened an hour ago after i put the headlights in. i haven't done any mods or touched anything electrical.
2004 Acura TL
it's back at the shop i had it in. he took responsibility for it so he's attempting to fix it.. i also took out valuables just encase someone wants to take something
Wow, so he has a guilty mind over this? Wonder what he knows about it? Well, that's good news I suppose. You might want to mention fuse 32 to him, although now I wonder if it's something more serious than a fuse (i.e. employee abuse)...Good luck, keep us updated.
04 Acura TL A-Spec
you can get the radio code by holding the number 1 and 6 preset for the radio stations, 2 sets of numbers will come up on the dashboard (not the navigation), those numbers represent the serial number of your radio, you can take this number to an acura dealership and they can get you the codes or you can track it down online with your vin number as well to contact the original dealership that sold the car as they would have the radio/navi codes, once you get the code turn the radio on like you would normally and the dashboard will say "code", then put in the radio code using the presets
u dont have to take the radio out to find the serial # jus open the glove box and its on the side of the box facing the driver side....turn ur car on and jus enter the code it should b 5 or 6 #s
Jamus22
06-11-2023 10:08 AM
dirleton
09-28-2015 04:48 PM
