Radio(AM) doesn't work while audio does
Old Jul 30, 2012 | 03:47 AM
TL_Pang's Avatar
Unhappy Radio(AM) doesn't work while audio does
I know there are similar threads and I spent a good amount of time doing research but I couldn't find a situation that is like mine.
So I have a 06 TL with navi (in Canada). So when I listen to the ratio (FM) it works fine in most area, but there are some area that I get static noise. In some area, the static noise is not that bad but some area is really bad to the point i had to turn it off.
And if I listen to AM then it gets static noise EVERYWHERE, so I can't listen to AM at all. CD and iPod work great. Also, my rear window is not tinted. So someone please help me!! The problem is driving me crazy!! Appreciate any info
Old Jul 30, 2012 | 05:58 PM
TL_Pang's Avatar
no one?? please helpppppppp
Old Aug 2, 2012 | 09:04 AM
LoveMyTL-S's Avatar
Is the antenna connected?
Old Aug 2, 2012 | 02:47 PM
TL_Pang's Avatar
how do i check if it's the antenna?
Old Aug 3, 2012 | 01:13 AM
I hate cars's Avatar
The plug for the rear window antenna and the defroster are behind the driver's side rear quarter panel. Remove the inside panel with the airbag label by the rear window and you will see what Im talking about. When I got my car back from the shop once I had the same problems you're having plus the defroster didn't work.
Old Aug 4, 2012 | 01:07 AM
TL_Pang's Avatar
image host
Is this what u were talking about? I only took out this part and saw the plug which is on the 2nd picture and i tried to unplug and plug it back on but no luck... I didn't take out the airbag part because I felt like i was gonna break sth..tell me if i need take out the airbag part as well n tell me I can just use my force and pull it out...
thank u!
Old Aug 4, 2012 | 02:00 AM
Nope, it's the side piece. You pull the "airbag" clip out and the panel will pry off. Once in there you will see the two plugs, one for the heater, one for the antenna from what I remember from 5 years ago.
Old Aug 4, 2012 | 07:16 PM
TL_Pang's Avatar
picture hosting
Ok, so i did what u said. you mentioned there would be 2 plug, I assume it's the red and green narrow that are pointing right? I unplug and plug them both back in and still nth happened
Old Aug 4, 2012 | 07:43 PM
I believe its the white plug in the background.
Old Aug 4, 2012 | 08:55 PM
TL_Pang's Avatar
I unplug and plug it back on but nth happened...sth else i should try?
Thanks!
Old Aug 4, 2012 | 09:21 PM
Ken1997TL's Avatar
The plug in the headunit came undone?
The wire connecting the antenna to the head unit got cut?
Can't really think what else it might be.
Old Aug 4, 2012 | 09:35 PM
Now that I'm on a computer and can see lol, the white one looks like the defogger. There should be another plug that goes to the glass. Try that one. I think it's higher up.
Old Aug 4, 2012 | 09:44 PM
TL_Pang's Avatar
free picture hosting
r u talk about this? there are a few of these plugs that connect with the glass on the both side of the glass. i tried to unplug it, but it's really hard to do it
Old Aug 4, 2012 | 09:50 PM
Where does the green wire go?
Old Aug 4, 2012 | 10:42 PM
TL_Pang's Avatar
U mean the actual green wire or the green narrow that I draw?
AndrewS
19
Mar 14, 2024 06:59 PM
Ol'Dave
Sep 5, 2020 02:56 PM
sockr1
Oct 1, 2015 01:31 AM
acurajj
Sep 19, 2015 03:47 PM
vanderveen44
ILX
Sep 2, 2015 01:48 PM
