Quick question .....
Old Aug 16, 2012 | 03:30 PM
BlitzBlackGSXR's Avatar
Yes I've searched and found the info. But I just wanted to make sure that it will work.
Ok, I will be installing a amp as soon as all my install gear gets here.
The amp :
Memphis M-Class 16-MC2.100 ( this amp will be used to power 2 Image Dynamic ID8's )
On the amp is has dip switches for balanced and unbalanced input. I would need you leave the dip switches on balanced and use this Kicker 09ZISL 2 channel signal cable and wire in the sub inputs from the stock sub wireing to get my singal to the amp , correct ? As the amp accepts balanced inputs .
Signal cable :
http://www.sonicelectronix.com/item_...857-141-700-53
Rdub81
ILX Photograph Gallery
Mar 17, 2016 03:02 PM
06TLMatt
Oct 2, 2015 08:14 PM
Strath
Sep 27, 2015 11:53 PM
HOWELLiNC
Sep 20, 2015 04:21 PM
datadr
Sep 12, 2015 09:12 PM
