Question on Viper Alarm/Starter
![Talking](https://acurazine.com/forums/images/icons/icon10.gif)
Hi everyone, so I'm thinking about installing an alarm/starter Viper 5902 on my 08 TL. I'm getting parts online and then have them installed to save some $. Here are what i'm getting:
Viper 5902
Bypass PKH34
Audio Glass Break Sensor
(yah, been broken in)
Am I missing anything that is needed in order to complete the installation? Also, after the installation, will I still be able to use the lock/unlock/trunk pop functions on my Acura key?
Thanks for any input.
Viper 5902
Bypass PKH34
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
I would recoment bying the parts and have them installed at the same location. If a worrenty issue comes up then you don't have to deal with anything. P.S. I work for a manufature of alarms and starters that is not Viper. So i will stay out of the what product to buy. However from my expirance as an installer and dealing with customers, I highly recomend getting both the equitment and the install at the same place. Some Companies don't suport warrenty on products purchased online. Just and FYI.....
OP looks like your all set to go
. & you should be able to use the: lock/unlock/truck pop & window roll down from your factory key fob.
CarologistFB, I agree with you 100%.
But if you must buy it elsewhere from the place installing it, get some warranty coverage for it. Which was what I did, I got a three year warranty coverage on my 5901.
But I believe everything you list is what you need. Not sure tho.
door lock interface module? or do you want it hardwired?
One way is threw the data wires on the car, the other is run one wire per function to that circit in the car.
The Data way tyipicaly requires less time and less wire conections in the car.
The Hardwired method is tried and true it works and is the older way of doing things.....
However not all cars will have a the ablity to use data. In some cases such as the 3g the data wires will work until the car is started and then they will not work. so you would have both styles of conections in the car. Not all Bypass and interface modules are the same.
I hope that this answers your question.
Huh? Not true. I have the canmax400dei doorlock/bypass combo module and I can lock and unlock doors while the car is running. Nothing is wire to wire, all data to data.
Depending on how the interface is locking and unlocking the doors..... I.E. threw the Keyless module, which is ignored when the car is running..(try locking/unlocking the car with the factory remote while it is running, in some makes of vehilce it doesn't work) with that said the interface module has wiring direction to make the use of the remote seemless to the end user... again not all interfaces are the same.....
umakemekissu
You are all set with what you were planing to have installed. You should not have any problems with that equitment....
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
