Question For Carputer Owners
i am looking into installing a carputer and i was wondering instead of moving the AC and stereo display to the bottom compartment can i just get the clock display from the navigation model from the TL which basicly displays the same things
For the clock display on the navi model to work in a non navi car you will still need to get the actual navi LCD screen for that display to work as I think Moahdib said it sends the info from the LCD to the clock display. If you look in his pics you'll see the navi screen (covered by cardboard) tucked behind his other Xenarc in the bottom compartments for that purpose. Also I don't think the clock display in the navi car displays ALL of the stereo's info either, anyone correct me if I'm wrong. It would defintely simplify things if it did..
Been a while Im thinkin about those 2 possibilities and I found that moving the LCD down was the less expensive and the easiest way. You still need to extend some wires for the LCD but thats about it.
If you're doing as moahdib did your gonna loose your Headunit info, maybe you can find a way to collect that info with the PC but that's an other story.
I prefere moving the LCD down looks nice and I don't even use those little space compartment. 2 sents!
Good luck on your installation!
Sorry for the mistakes, look at this thread. It seems that the navi clock display the headunit INFO!
https://acurazine.com/forums/religion-politics-18/israel-had-plot-kill-saddam-hussein-124638/
IIDXholic
Oct 8, 2015 07:53 AM
