Question on burning 4.62 DVD
Do i need an iso program like daemon tools to mount the image, or do i actually burn the .iso file without unpacking it? I'm not sure what i did wrong. I opened up the .iso image and burned the contents with roxio at the slowest speed (2.4x), burned onto a dual layer dvd+r. When I popped it into my '07 TL-S, I got a disk read error. Any help or ideas?
Originally Posted by jayv
i burned it using Roxio Toast Titanium on my Mac. I Mounted it and then just burnt it as a disc image.. i had no issues at all...
You burned it as a disc image? I'm not sure what that means. I mounted it and opened the containing folder, then just copied the contents, and pasted into roxio and pressed burn. Is that right?
i believe that is where you are having your your problems is the copying and pasting... I could be wrong though.. i can check when i get home tomorrow.. im at work tonight..
Received 6,470 Likes
You might PM "Igor911"- he has a thread in this section of the site. He burned it and it is working fine. I don't know if he tried to get rid of the "OK" on the front end or not. Here's his thread:
https://acurazine.com/forums/showthread.php?t=179990
did you figure it out yet? Like i said i used Roxio Toast 9... Under copy it has a selection for iso... just choose that and hit burn.... It shouldnt be much different for PC... Hope that helps.. JV
B A N N E D
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
