Question for anyone with Escort Radar detectors
I purchased an Escort 8500 X50 with the hard-wire optional kit (which has alert lights and a "Mute" button). So, obviously, I want to hard-wire my detector into my TL.
My question is: Where?
Have you had good luck / bad luck with your installation that you can share, or anything that you would recommend (or recommend not doing) about your installation?
Note: I'm going to let Best Buy install it for around $30.
Here's a thread to get you started until someone who has one comes on line http://www.acura-tl.com/forums/showthread.php?t=76187
Pretty easy job.. if you have a fair amount of knowledge about cars, it shouldn't take more than 30 minutes. The only thing you are going to have to be careful with is taking off the pillars (people usually break the courtesy-tabs that holds the pillars in place). Good luck!
Originally Posted by MikeRadio
How LOUD is this detector the 8500 X50?
is it louder than the Bel RX 65?
The 8500 X50 is very easy to hear. I have the volume dial up around 70%, and it's plenty loud for me, with the radio up around 20 (occasionally).
I got the hard wire thru Best Buy and they did a excellent job. It took just under one hour to do the job. God knows how long it would have taken me.
Well worth the money. Very clean look
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
navtool.com
Sep 25, 2015 05:15 PM
