Question about stock sub...
Old Sep 23, 2009 | 10:05 PM
daballer2005's Avatar
I plan on putting my 2 12" JL W3's this weekend, i was wondering if i should leave the stock sub plugged in or not?
Im replacing the 6x9's too.
Old Sep 29, 2009 | 04:41 PM
slimjim2's Avatar
Well, if you have a tl 04 or later, then you have 6.5 in in the deck with the stock 8" sub. you should search these forums about this topic. There are only about a million posts. You will find easiest install to take line level straight from sub to a LOC (line-out-converter), then RCA to your aftermarket amp. You will should disconnect so you don't get interference between different sized subs (which u will get)!
Old Sep 29, 2009 | 05:29 PM
King of Pain's Avatar
Do you have a 3G TL? Where are the 6x9s located?
IIDXholic
Oct 8, 2015 02:27 PM
datadr
Sep 12, 2015 09:12 PM
bailey24
Aug 31, 2015 05:38 PM
