Putting in a system
Old Mar 30, 2015 | 09:03 PM
Lsoileau's Avatar
Putting in a system
In my 05 tl do I need to get an after market radio before putting in a system??
Old Mar 30, 2015 | 09:56 PM
CrazyEights's Avatar
So not a sociopath
I'm going to go out on a real short limb and guess you didn't search before you asked that question.
I'm also going to give a real short answer.
No
Old Apr 1, 2015 | 03:07 PM
JD TL-S's Avatar
You can add a 4-ch amp for the 4 main speakers.
If so- get an amp with Hi-level inputs.
Leave the center speaker + OEM amp as is.
If you want a bigger subwoofer- also buy
a mono sub amp with Hi-level inputs and a
12" single sub in a sealed small box-3/4" MDF.
Call Cruthfield if you don't undertand me.
Old Apr 1, 2015 | 04:00 PM
heisohio's Avatar
7th Gear
Thanks for this. First day on the forum. Picking up my 08 TL next week.
Audio will be important upgrade.
Old Apr 2, 2015 | 12:39 AM
chrisd421's Avatar
U don't need hi level inputs. Your best bet is to find someone that knows how to solder wire leads onto rca's (unless u can). Then tap into the wiring before the amp. A good majority of 3rd gen tl get a hum from the factory amp going bad and you can avoid that by tapping in pre amp and just run rca to the amp. You get better sound anyway
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
snorf
Nov 4, 2019 06:44 AM
