Problem pairing TL w/motorial razr v3
I just got a TL and a motorola razr phone and can't seem to pair it. I follwed the instructions, which say to enable bluetooth on the phone, and then use the handfreelink command 'phone setup'. The response is supposed to relate to specifics of the phone setup, and you are supposed to respond 'pair'. Unfortunately, the response just takes me to the regular setup screen and asks 'what do you want to set up'.
Something must be out of date here. The manual? Has anyone run into this problem and found a solution? Many thanks!
Not sure why you posted the same question in two different threads, so I deleted your other thread. After you tell the HFL the 4 digit number you want to use, go to the bluetooth menu in the razr, click on "handsfree" then click "look for devices" when tthe car and the phone are searching for each other, they will find each other.
SidhuSaaB
May 30, 2020 12:40 AM
DementiaPhuro
Sep 29, 2015 05:31 PM
rboller
Sep 23, 2015 02:49 PM
