Problem with my V3 and TL
Old Dec 19, 2004 | 02:48 AM
ck37's Avatar
just got my V3 razor from singapore. Received the complete kit with the HS810. I love the phon but for some reason the TL and the V3 keep disconnecting. I constantly get "weak bluetooth signal use handset?" with the V3 however the headset works well with it. Should I get the bluetooth module checked out on the TL or is there settings in the V3 i should know about. any help would be greatly appreciated.
thanks.
Old Dec 19, 2004 | 10:49 AM
topprospect's Avatar
Could you check your firmware version? I know that my V600 had a similar problem until I updated my firmware to TRIPLETS_G_0B.09.4AR and I believe the V3 uses the same TRIPLETS firmware builds.
Old Dec 19, 2004 | 11:21 AM
ck37's Avatar
My firmware is R374_G_0E.40.3DR
The range with the headset works great, its just the TL that has problems.
Old Sep 20, 2005 | 07:38 PM
foot3ch's Avatar
I have V3 w/ T-mobile R374_G_OE.40.9ER Connection is fine but nothing display on my car.
Old Sep 20, 2005 | 10:01 PM
SonicDark's Avatar
I have a Black RAZR from Cingular unlocked for TMobile
It's not nearly as good as my V710 from Verizon but to improve it you can get the newest firmware for the RAZR at motomodders or mottomodders.com. They have step by step on how to do it.
It improved the connection for me although I still only have signal strength, not battery level with it.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
