Problem with memory seat settings.
Old May 8, 2009 | 05:09 PM
palacio12's Avatar
4th Gear
I've noticed that my memory buttons on the driver door doesn't work anymore. Whenever I press the 1 or 2 button, nothing happens. Could it be a fuse that went out or is there possibly a different problem with it? Any help is appreciated.
Old May 8, 2009 | 08:48 PM
LoveMyTL-S's Avatar
You can check the fuses. Are you able to unlock the car or open the trunk with the FOB? If not, it may need re-programming.
https://acurazine.com/forums/3g-tl-2004-2008-93/programming-remote-transmitter-keyfob-3g-garage-l-079-a-556315/
I'd check the fuse first. Is the member button lit at all?
Old May 8, 2009 | 09:08 PM
StYLeZz101's Avatar
i had a similar problem where it would lose its memory quite often...took it into the dealer and they replaced the memory unit
Old May 8, 2009 | 09:24 PM
palacio12's Avatar
4th Gear
Yes I'm able to unlock the car and the trunk with the FOB and no the member button isn't lit. How much was it to replace the memory unit?
Old May 8, 2009 | 09:53 PM
StYLeZz101's Avatar
mine was replaced under warranty so it was no charge...but looking at acuraoemparts.com its
81628-SEP-A02 M.S.C. UNIT 1 2004 TL $111.15 $83.3(price you pay)
i have a 2004 thats y i looked for that one
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Old May 9, 2009 | 04:27 PM
palacio12's Avatar
4th Gear
Well I checked the fuse today and everything was fine so I'm guessing its' the memory unit. Has anyone replaced one of these?
rockyboy
Aug 4, 2024 10:35 AM
miner
3G RLX (2013+)
36
Jan 11, 2016 04:17 PM
Azonics
Sep 22, 2015 05:28 PM
