Problem with Dom's Unit - ghosting
Old Jul 3, 2007 | 09:05 AM
cj1raven's Avatar
Unhappy Problem with Dom's Unit - ghosting
I've had Dom's tvandnav2go installed in my TL since the beginning of the year, with no problems. Last week I noticed when it was really hot out I couldn't see the nav screen. It didn't matter whether it was switched to dom's unit for my mediaplayer or switch as a pass-thru for the nav. I couldn't get anything. Later on it would start working (lower external temps?). Now it doesn't seem to work at all, but I can see a light ghost of an image when I'm under shade or at night, so the image is there. It's just not bright. I disconnected Dom's unit and plugged the nav into itself (oem) and it worked fine.
Has anyone had this problem? Any bad navandtv2go units?
Old Jul 3, 2007 | 03:03 PM
dennisil's Avatar
its solid state construction is basically fail safe, contact dom but also re-check your connections.... good luck
Old Jul 9, 2007 | 03:15 AM
datmrman's Avatar
Check your connections. I have seen the ghosting before when Dom's unit wasn't powered/grounded correctly.
Old Jul 9, 2007 | 06:30 PM
csmeance's Avatar
check the ground wires and reground if nessary. Where are you getting power for dom's unit? You should be getting it to a steady clean source. I used the center console power outlet.
Old Jul 12, 2007 | 08:40 AM
cj1raven's Avatar
You are correct datrman. No juice to Dom's unit all of a sudden. So I guess it's using whatever power it can get from elsewhere to give me the faint image. Apparently, the connector for power came loose from the wire it was tapped into. Thanks for your help.
Old Jul 12, 2007 | 03:27 PM
dennisil's Avatar
datmrman saves the day again!!! sure i told you 6 days before he did to check your connections but i guise you needed a moderator to get you do try it... im just kidding i remember when i was installing my stuff and i was sending him like 10 pm's a day! datmrman is da_bomb!
Old Jul 14, 2007 | 01:38 AM
datmrman's Avatar
Its all good as long as the problem is fixed. Thanks for the compliments.
Glad we figured it out. Now I can point people to this thread.
Old Jul 14, 2007 | 11:14 AM
BrandonClaps's Avatar
Same...
edit: doh too late
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
Rachel Lu
Sep 27, 2015 09:53 AM
krenaue
Sep 15, 2015 07:54 PM
mporris
1/2G MDX (2001-2013)
Sep 13, 2015 01:58 PM
