Problem with AUX input jack
Old Dec 10, 2008 | 09:18 AM
dez's Avatar
dez
I never post !!!
Exclamation Problem with AUX input jack
Ok, so I don't have an IPOD, but I have one of those Sony 2GB MP3 players that is really cool. However, I cannot get it to work in my '08 TL through the Aux jack in the center console. I used the proper stereo cable and the AUX comes up on the Navi screen, but I get NO AUDIO. If I turn it ALL the way up (on the player and the car) I can hear very faint audio - definitely not even worth it. I can't imagine what the problem can be.
Does anyone else have this problem with other MP3 players or is there a solution? Something stupid I'm missing?
Thanks in advance.
Old Dec 10, 2008 | 11:07 AM
playa4real's Avatar
i take it that if you use headphones on your mp3 player the sound level is fine? If this is the case then it could only be one of 3 possible issues: 1. the male to male 3.5mm cable is bad or 2. the car's aux jack is bad or 3. you did not connect the cable all the way into the jack. Depending on where you got your cable from, i'm going to assume that your issue is number 3. Try pushing the connector at the end of the cable all the way into the aux jack on the car - this should solve your problem. If it does not, then it is definitely the wire - must just be a crappy cable, buy a new one.
I'm pretty sure it's not the car's AUX jack, but you can always verify this by trying a different mp3 player and cable. If the jack is bad, no worries just go to the dealer and get it fixed under warranty.
let us know what happens.
Old Dec 10, 2008 | 01:55 PM
LoveMyTL-S's Avatar
Also make sure the cable is plugged into the player all the way. Is the cable stereo or mono?
Old Dec 22, 2008 | 09:26 AM
dez's Avatar
dez
I never post !!!
Turns out - it was a bad cable after all!
Bought a new one and all is well!!! Thanks!
Old Dec 22, 2008 | 09:59 AM
playa4real's Avatar
good to hear. thanks for the update.
Old Nov 30, 2013 | 06:56 AM
zoostation's Avatar
Is this cable a RCA male / male cable?
Old Nov 30, 2013 | 11:57 AM
ShaneN.'s Avatar
what models have an aux jack? i have an 06 with no navigation and i can't see how i'd plug in my phone to listen to music with this car.
Old Dec 1, 2013 | 05:15 AM
zoostation's Avatar
I think it's 07 and 08. And I confirmed yesterday it is an RCA / RCA connection.
Old Dec 1, 2013 | 10:38 AM
ShaneN.'s Avatar
i can't believe this car has no l/100 kms or info like that, no aux jack, no bluetooth audio playing and it doesn't play mp3's. i had a tsx for a while in the same model year and it had all of that.
BadassAcuraCl
1G CL Problems & Fixes
Sep 14, 2016 03:26 PM
BIGxRED
Sep 26, 2015 02:16 AM
navtool.com
Sep 25, 2015 06:21 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
NSolace
Sep 3, 2015 08:02 PM
