power wire??
Old Apr 17, 2009 | 09:38 AM
dREaM'n TL's Avatar
power wire??
can someone post pictures of their power wire through the firewall. i cant figure out where in the firewall i should run the power wire. thanks
Old Apr 17, 2009 | 10:16 AM
csmeance's Avatar
its in this thread:
https://acurazine.com/forums/showthr...314&highlight=
Old Apr 17, 2009 | 10:31 AM
rodneyc77's Avatar
Retired!!! ON TOP!!!
Originally Posted by csmeance
That's the route for a 6-Speed... the route for the automatic is much easier to access since it's to the right (view from engine bay) or to the left (view from inside the car), where the 6-speed uses the opening for the clutch master cylider...
You'll be sharing the gromet opening of the main wire harness coming into the car...
The easiest way is to run the wire from inside the car...
Good Luck....
Old Apr 17, 2009 | 01:34 PM
msala524's Avatar
08 TL-S NBP
Yea, I have run some wires through the steering column which is very easy as well.
Old Apr 17, 2009 | 03:57 PM
ezland00's Avatar
where is a good location in the trunk to drill a hole for ground?
Old Apr 17, 2009 | 05:11 PM
SR-71TL's Avatar
^ You don't need to drill at all. If you lift up the carpet in the trunk there is a bolt to the left of the fuel tank by the rear of the seats. I used that one like in the sub install thread from Death to Toasters I think it was. Hope that helps.
Old Apr 17, 2009 | 06:07 PM
dREaM'n TL's Avatar
what is a good location for ground. i used fuse # 30 is that a good location
Old Apr 17, 2009 | 07:04 PM
fade2blk's Avatar
Why would you use fuse # 30 for ground?
ground goes to metal, frame, negative side of the battery..... do not connect ground to a fuse.... bad things will happen.....
Negative ground An electrical system where the chassis is the negative side of the circuit and a separate wire to each component is the positive (hot) line.
Ground
(GND or GRND)
Terminal of Battery that is connected to the metal framework of the vehicle so that the Frame acts as a Conductor of electricity. In North America, the Negative terminal is grounded. In British terms, it is called Earth.
Old Apr 17, 2009 | 09:51 PM
dREaM'n TL's Avatar
i meant remote wire. not ground
Old Apr 17, 2009 | 11:10 PM
fade2blk's Avatar
gotcha.
yes you can use that. you can also use a remote of the back of your dvd player if you have NAV, or you can use remote of the xm unit @ the trunk. if you have that.
Acura604
20
Aug 5, 2017 12:55 AM
Jul 16, 2017 07:33 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
