Power Antenna question
Old May 30, 2009 | 02:39 AM
ezland00's Avatar
I have a aftermarket headunit install, Pioneer avic-700bt w/ HD receiver. My HD radio jumps between analog and digital signal all the time. I have done some search, and need some help. According to crutchfield information, Pin #10 is power antenna; does it need to be connnect to any power source? if so where can i connect it to.
pin 10 "The YW/GN wire triggers the booster for the in-glass antenna"
Also i have installed a aftermarket amp, can the OEM power amp be completely removed without causing any problem.
thanks
Old May 30, 2009 | 07:08 AM
Trew's Avatar
Not sure about any OEM antenna boosters, but that power antenna lead can be used as a remote wire for the amp.
Old May 30, 2009 | 11:03 PM
pilotman28's Avatar
I believe the "power antenna" would be for if a vehicle had a retractable antenna, just a guess.
oyayjoe
Jan 1, 2019 10:17 PM
VA2000TL
Oct 2, 2015 08:26 AM
vanderveen44
ILX
Sep 16, 2015 10:51 AM
datadr
Sep 12, 2015 09:12 PM
oyayjoe
Sep 12, 2015 04:40 PM
