Please recommend speakers for me.
Old Dec 18, 2008 | 12:14 PM
thelinux's Avatar
I got a new 2008 TL and would like to replace all speakers.
I don't know much about car audio install. So I just want to replace all speakers and use stock amp.
I am looking for something I can do simple replace and play thing. No modification to the grill or door panel or running wires or anything like that.
Just take out old speakers and replace them with new ones. That's what I want to do. I am willing to use new grills if it comes with new speakers and it fits with existing holes any modification to interior of my car.
So what speakers would you guys recommend for each channel?
Old Dec 18, 2008 | 02:27 PM
eggyhustles's Avatar
no purpose in upgrading the speakers if you aren't gonna amp them
Old Dec 18, 2008 | 02:47 PM
anarchy[sear]'s Avatar
KICKED IN THE BALLS
get some nice compontents sets for the car and a nice center speaker. Get yourself an amp it doesn't have to be a monster of an amp. Have fun installing the rear speaker.
Old Dec 18, 2008 | 06:08 PM
Trew's Avatar
https://acurazine.com/forums/members/trew-250256-albums-door-speaker-components-upgrade-256/
Old Dec 18, 2008 | 06:49 PM
RJANACONDA's Avatar
Registered TL Lover
I happily disagree with you I upgraded my speakers in my 04 with Polk components and the differance is night and day. I only have and afermarket amp for my RF sub.
my componets
https://acurazine.com/forums/showthr...8551&highlight=
my sub
https://acurazine.com/forums/showthr...8678&highlight=
I actually have the newer sub of that line that is DVC and better power handling. but it looks the same
Old Dec 18, 2008 | 06:58 PM
look like coaxils to me
if you amp them the sound would be night and day
Old Dec 18, 2008 | 07:29 PM
RJANACONDA's Avatar
Registered TL Lover
no rca at all
just plugged the speaker wires into the honda speaker adapter harness and they plug directly into the stock connection. no need to solder or run additional wires. wich is what the OP wanted.
and with all the compliments on my system from car audio competition WINNERS I think that my system is more than enough.
Sure i could always add an amp if i wanted more volume or an EQ if I wanted to be able to tweek the sound more. But i can control that easier and for free by changing the sorce of the music.
Now if you want Ear drum Busting loudness then yes you NEED an amp but if you are just looking to improve SQ then speaker upgrade is all you need.
Old Dec 18, 2008 | 10:10 PM
rc2776's Avatar
Guys I got a new 2008 TL Type-S two days ago. It is an awesome car in all respects execpt for the audio. I was excited about the 8 speaker ELS DVD Audio system. Though quite a bit better than the stock system in my brother's BMW X5 it paled in comparison (I know I shouldn't have compared) with the aftermarket system I installed in my 1999 Honda Accord which got totalled. I would really like to upgrade my car speakers and Amp but I would still like to take advantage of the DVD Audio / Surround sound and not change the interior look of the car (in other words I don't want to drill holes for speakers or tweaters ... just replace stock speakers with better quality ones and I don't mind an amp and a subwoofer in the trunk). I am willing to spend upto a grand or even $1500. Any suggestions would be greatly appreciated. Also, any input about the possibility of any conflicts with the ANC (active noise cancellation) and external amplifier would be great. I will post this message of mine in couple other threads to reach the 10 posts need to take off the restrictions from my Acurazine account. Please bear with me.
Thank you all for your help.
Old Dec 19, 2008 | 03:58 PM
thelinux's Avatar
Looks awesome. But I don't want to make a bigger holes on the door or my NEW car. Maybe 2 or 3 years later when the new car smell goes away completely, then I might try that.
By the way, what is that thing called "Dynamat"??? I saw a lot of people using it. I guess it has something to do with sound improving or noise reduction. Does it make the interior of the car quieter? How does this thing work?
Old Dec 19, 2008 | 04:15 PM
thelinux's Avatar
my componets
my sub
What's the exact model number of those speakers?
Where is audio DIY 3gen TL? I can't find them.
Old Dec 19, 2008 | 04:16 PM
I hate cars's Avatar
no rca at all
The amp does improve SQ even though it gets it's signal from the stock amp. I first upgraded speakers only and ran them for a year. It made a nice difference. Then I amped them and it was just as big of a change.
Old Dec 19, 2008 | 08:46 PM
Trew's Avatar
LOL I understand. I waited over 2 years before I unfastened a single screw on my car.
Dynamat is a sound deadening material that does many things. To name a few, it reduces vibration and quiets the ride, which causes your sound system to sound a whole lot better.
Old Dec 20, 2008 | 04:13 AM
RJANACONDA's Avatar
Registered TL Lover
for the front and rear i have
http://www.crutchfield.com/p_107DB65...owAll=N&tp=105
center
http://www.crutchfield.com/p_107DB35...owAll=N&tp=105
Tweeter
http://www.crutchfield.com/p_107DB10...owAll=N&tp=107
Odds are you can find them cheaper at another place but crutfields site is pretty good about giving accurate info
as far as the DIY you will have to look at door panel removal and rear seat/deck removal.
Old Dec 20, 2008 | 04:19 AM
RJANACONDA's Avatar
Registered TL Lover
oops forgot
to install these speakers without cutting wires you will need the honda adapter harness crutchfield gives you them for free. tweeters will have to be cut spliced/soldered and require the the addition of some sort of noise cancelling circut put in line between the amp and the tweet (they come in the box with the tweeter you hjust have to put it in there)
Old Dec 20, 2008 | 04:25 AM
RJANACONDA's Avatar
Registered TL Lover
Yes and if you the OP plan to install the speakers yourself i reccomend puttting in dynomat or equivilant while you are doing the speaker install. the rear speakers are a PITA to get to with you haveing to remove the entire rear seat and rear deck (trust me you cant shortcut it ) and its not something you want to do more then once. So if you even remotely are think about dynomating then save your self some time and effort and do it at the same time. I wish I did
Old Dec 20, 2008 | 10:25 AM
thelinux's Avatar
center
Tweeter
I found this for door panel removal. https://acurazine.com/forums/3g-tl-2004-2008-93/front-rear-door-panel-handles-wstrip-glass-window-regulator-removal-3g-garage-f-016-a-603296/
Do I just need to peroform what is on the page 20-7 or do I have to go through page 20-8 too?
So you put the same speakers on the door and rear?
hashbrown
Sep 29, 2015 12:13 PM
San Yasin
Sep 29, 2015 10:52 AM
adreano17
Sep 29, 2015 08:48 AM
polish_pat
Sep 25, 2015 12:24 PM
