PKH34 immobilizer bypass wont work. Who has installed this bypass? Help me out!
I purchased the advanced keys keyless access and knob start system for my 2007 TLS 6mt. I spent the day installing that kit along with the required immobilizer bypass. I ended up using the expresskit PKH34 which I installed according to their directions and according to this detailed writeup from this forum (https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/very-detailed-install-viper-5901-remote-start-706816/#post10600162).
The install went great the keyless access system works as it should except the stupid PKH34 unit will not work. I cannot get it to program or do anything for that matter. I tested the wires 12v constant, ground, and ignition work as they should going into the unit. The data wire is hooked up as well as the security light output and input. What the heck is wrong with this stupid unit? I hate these bypass things.
Here is the wire diagram that I followed for the PKH34 unit. I used the "Type A" install method:
http://www.bypasskit.com/Manuals/698...1_D01_I_EN.pdf
Im about ready to run to best buy and see if they sell any other kits because im losing my patience with this one.
Thanks for any tips.
James
James
You mean you can't get it to program? Try resetting it; press the prog. button while you plugin the connector. It this doesn't work then you may have a defective unit. If you got it to program try ground the "Ground-When-Running" input directly the ground to see if you can start the car that way, if it does then you are good to go.
Greengecko
09-16-2015 08:19 PM
Abe_Froman
09-16-2015 01:27 PM
