Phone book
Phone book
Just got a 08TLS, but is there a speed dial feature when placing calls. It looks like I have to open the cellular phone book, choose my phone, and then scroll down to the find the number. There must be an easier to set the top 5 phone numbers that I usually dial.
Aren't you saving names/numbers into the HFL system address book?
If you have a Sony Ericcson phone, the numbers can be imported from your phone at once (up to a max of 50??); other cell phones require that numbers be imported one at a time.
Otherwise, you can enter frequently-called numbers with voice tags into the HFL per the manual, the way those of us with the '04-'05 TLs do- Home, wife, girlfriend, boyfriend, etc. Then you can just push the HFL button, say "Call [voicetag name]," push the button again or say yes to confirm, and the call is placed...
I dont think you can use HFL with imported phone books unless I missed something. You can manually add each imported entry, but at that point you might as well just enter each name and number and use the voice dial like Will Y said.
mlody
Dec 4, 2019 02:11 PM
