Phoenix Gold Octane-R 5.1
Old Oct 7, 2004 | 10:44 AM
Hawhyen51's Avatar
Hey all, don't know if anyone posted on this yet. For all of you guys looking to upgrade ELS amplification.....Phoenix Gold has a new 5.1 amp Octane-R 5.1 Wondering if it can be adapted to the current wiring harness
Basic Specs:
6 Channel Power Amp
100x5 (4 Ohms)
200x1 (2 Ohm) Max
SNR >100 dB
Freq Response 20-20,000Hz
Built in digital Surround Proceesor
TosLink Optical RCA Coax Digital Inputs
Subwoofer Preamp output
24 Bit A/D*D/A convertors
Composite RCA video Input and Output
MSRP $499
Read the review DVD ETC. nov-Dec 2004 issue......
Old Oct 7, 2004 | 06:32 PM
spyfish007's Avatar
It doesn't have 6 channel inputs. It has 4 channel inputs and and you can select between A/B. In this setup you would lose control from the head unit.
Old Oct 8, 2004 | 11:32 AM
Hawhyen51's Avatar
Spyfish, the picture of the amp I'm looking at has 6 channels, Front L/R, Rear L/R, Center and Sub. It was reviewed as a 5.1 system with 6 discrete channels. Are you refering to another amp in their product line?
Old Oct 8, 2004 | 01:24 PM
spyfish007's Avatar
I have the product manual if you want me to send it to you? The amp has 6 discrete OUTPUTS, not INPUTS! The only way to get the 5.1 input is to use the coax or optical input. There are only 4 channels of RCA input (A&B w/L&R on each) and you can select between the two. This would render the head unit controls useless for fade, center, & sub. That is not a good solution. If you want an amp that can do that look at the PG Ti900.7 amp.
Old Oct 8, 2004 | 11:41 PM
Hawhyen51's Avatar
Spyfish, thanks for clearing it up for me...... thought it might be a viable solution/option.
Old Oct 9, 2004 | 12:29 AM
spyfish007's Avatar
I've been searching for a replacement amp too so I had already examined that amp.
Old Oct 11, 2004 | 10:25 AM
Hawhyen51's Avatar
spyfish, when you find one, please post and again thanks.......
Old Oct 11, 2004 | 10:20 PM
spyfish007's Avatar
I did post one ... the PG Ti900.7 amp.
mada51589
Jan 9, 2025 04:40 PM
Jul 16, 2017 07:33 AM
gatrhumpy
19
Dec 31, 2015 04:22 PM
mugen_kid
Nov 13, 2015 10:38 PM
