Parasitic battery drain
Old Oct 23, 2017 | 01:35 PM
PT6tech's Avatar
4th Gear
I have a 2008 Acura TLS. Battery going dead when sitting for a few days. Check parasitic drain at 0.23 amps. Found interior fuse had voltage drop. Removed fuse and parasitic drain dropped to 0.03 amps. Checked no interior lights on. Is there a timer module associated with the interior light system that may not be going to sleep? Can't find wiring diagram to trouble shoot system
Old Oct 23, 2017 | 01:37 PM
the HFL (Hands free link) unit likes to malfunction and drain the battery, parasitically.
Old Oct 23, 2017 | 01:44 PM
PT6tech's Avatar
4th Gear
Do you know where the HFL is located in the 2008 TLS? Any information is appreciated if I don't have to take to dealer to fix. Thanks.
Old Oct 23, 2017 | 01:47 PM
www.acura world . com /tsb/3gTL/b05-020.pdf
remove spaces
Old Oct 23, 2017 | 01:57 PM
PT6tech's Avatar
4th Gear
Thank you thoiboi for the information. Will try troubleshooting with the HFL disconnected, to see if parasitic drain goes away. Will let you know what happens.
Old Oct 24, 2017 | 07:28 PM
PT6tech's Avatar
4th Gear
Unplugged HFL. Parasitic drain went away. HFL was also warm to the touch when removed. Youtube has many uploads of HFL issuses, but not many about the parasitic drain on the battery when it malfunctions. Guess I can leave it unplugged since I don't use the bluetooth phone connection.
Old Jan 8, 2018 | 03:47 PM
DrewH's Avatar
I have a 2008 TL with the same problem. My battery would be dead after a couple days on non-use. I put the meter on the battery and it was drawing about .3 amp when the car was asleep. I disconnected the HFL and it dropped to .03 amp! I too do not use HFL and so left it unplugged.
Thanks folks for the info!
Old Jan 29, 2018 | 08:15 PM
alum04org's Avatar
Arrow
Am dealing with this problem right now. 2008 TL-S with 97K miles - fresh battery installed August 2017 and HFL puked around October, 2017. Have twice returned to car after four days of no driving to find a no-start situation. I've been studying all related threads and the Acura Tech Serv Bulletin, preparing to dismantle and remove the HFL module. Problem is, I suck at using tools and am quite capable of breaking any interior pieces I come in contact with
Old Jan 30, 2018 | 03:30 PM
tds166's Avatar
This is very easy to remove. If I remember its like 4 total bolts and all in the upper console lights/moonroof area.
Old Mar 12, 2018 | 12:52 PM
kliqzero's Avatar
went through same thing with my 05 acura TL - ended up being the HFL module. There are youtube videos out there of now how to remove, or you can take it to your local GoodYear and they'll do it for $50
Old Mar 12, 2018 | 01:01 PM
TacoBello's Avatar
A friend of mine has an 05 TL (with about 48k miles in it ), and his car started having the parasitic draw recently. I told him about the HFL malfunction, so he unplugged it also, but he said the issue is still happening. Is there something else that can cause a battery draw issue?
Old Mar 12, 2018 | 01:10 PM
AC relay
Old Mar 12, 2018 | 02:43 PM
Joecop67's Avatar
48k miles? Who cares if the battery is dead, you don't need a working battery to keep the car in the garage.
Old Mar 12, 2018 | 02:55 PM
Old Mar 12, 2018 | 02:59 PM
TacoBello's Avatar
Yeah, but that once a week on Sunday morning, newspaper run needs to be done comfortably
Old Mar 12, 2018 | 03:01 PM
Joecop67's Avatar
Old Mar 17, 2018 | 10:36 AM
mb.3g's Avatar
Late to the 3G Party
Taco A buddy of mine has had a problem with his oem head unit for about a year now. The button lights stay on and eventually drain the car. He has swapped head units, pulled fuses and prodded with his Fluke but still can't find the issue. Solution? Remove the radio altogether. It's rare but I think as TL's get older this problem will become more widespread.
Old Mar 30, 2018 | 12:07 AM
dope!'s Avatar
I'M BACK!!!
AC relay
what happens with the a/c relay? My car keeps draining my battery as well. HFL was removed years ago, just replaced my battery a few days ago and it drained it once again! None of the lights stay on and i had my alternator checked today. im stumped!
Old Apr 8, 2018 | 11:10 AM
preets22's Avatar
4th Gear
LOL. Honestly, its not too bad at all. I tried baking mine like the other threads suggested and it worked. No more battery drain and working HFL again!
peewizzle
Sep 9, 2019 06:57 AM
Dominique Glass
Oct 27, 2016 05:08 PM
rets
Jan 1, 2013 09:50 PM
langjae
Sep 4, 2002 01:07 PM
drewha174
Nov 13, 2001 01:05 PM
