OEM Navigation Information
Old Sep 2, 2009 | 10:14 AM
TheChamp531's Avatar
Chapter Leader (San Antonio)
Sorry if most of these can be searched, in a hurry!
Anyways, do 04 NAVI fit 06? 07-08 NAVI fit in a 06?
I have a Non-NAVI NBP and what will I need to make sure I have when I buy a NAVI used. I found a local craigslist ad selling the NAVI system and I always wanted NAVI so its time. What else should I know? I know I must have a security code just in case from the seller.
How much does something like this cost to get installed at a mechanic or dealer? I can probably DIY, but I'm not sure in doing this, especially when wires are involved.
Thanks for the help!
Old Sep 2, 2009 | 10:50 AM
kenny416's Avatar
If you convert 04 Navi into 06, there's not much difference, just minor things that you need to change. If you convert 07-08 Navi into 06, you need to make sure you have the HFL unit (08), sub-display screen and connectors (all types). Dealer won't do this conversion because there's a lot of things to do. But if you're lucky you might run into someone(ziner) here who can install it for you for a few hundreds.
Old Sep 2, 2009 | 12:44 PM
Over $300 for install? :-/
The one I'm buying has no wiring harness. Can I buy them? If so how much?
Thanks for yh
Old Sep 2, 2009 | 02:03 PM
kenny416's Avatar
Thanks for yh
jptl04 may help you for the installation.
For the harness
I've heard that people from ebay sell at $499 for 04/06 and a bit more for 07/08 version.
Old Sep 2, 2009 | 02:11 PM
For the harness
I mean just the wires, i got navi screen n stuff
Old Sep 2, 2009 | 02:49 PM
kenny416's Avatar
That's what I'm talking about. When I say harness, I met the wires. If you think it's too expensive for you, then I guess it's best if you customize your own harness so that it'll be cheaper for you.
Old Sep 4, 2009 | 11:53 AM
How much you think it will cost for a full NAVI conversion assuming I get the NAVI screen, cd/dvd.
I don't see no wiring harnesses on eBay or anything like that...
Old Sep 4, 2009 | 07:10 PM
kenny416's Avatar
All depends on if you want 04/06 or 07/08, and install now or later?
It's approximately, $1200-$1500.
For the wiring harness, you need to search the junkyard near where you live or other states, maybe in Canada as well. Normally, they remove the system and they scrap out the harness. Now, they know because so much ziners or peoples looking for this harness so they jack up the price or sell the whole unit with harness for more money. Therefore, the guy from ebay named is "Martin" sold a lot these harness to the ziners. For me, I can't affort to buy that harness for $600...That's why I build my own
Old Sep 8, 2009 | 09:04 AM
bzyrice's Avatar
You still need more parts then the navi screen and dvd.. If purchased new it comes to around 500.00. Plus, you still need the wiring harness either made by yourself or purchased from someone. I asked jptl04 and this guy martin on ebay.. and they both wanted more than 300.00 for the wiring harness because it is a pain to make.
35890-SEP-A11 SWITCH ASSY., NAVIGATION GUIDE& HANDS FREE TELEPHONE
39541-SEP-A40 BRACKET, NAVIGATOR ELECTRONIC CONTROL UNIT
84651-SEP-A01ZA LINING ASSY., L. TRUNK SIDE ( GRAPHITE BLACK )
39710-SEP-A41 DISPLAY ASSY., INFORMATION CENTER
39835-SEP-A51 ANTENNA ASSY., GPS
90132-SV4-003 SCREW, ET (5X16)
91540-S0A-003 CLIP, HARNESS BAND (96.9MM) (NATURAL)
91601-SH3-013 GROMMET, SCREW (5MM) (BLACK)
93893-05008-07 SCREW-WASHER (5X8)
93901-25280 SCREW, TAPPING (5X12)
77350-SEP-A00ZA COVER, COLUMN (UPPER) ( GRAPHITE BLACK )
77360-SEP-A00ZA COVER ASSY., COLUMN (LOWER) ( GRAPHITE BLACK )
Old Sep 8, 2009 | 10:21 AM
KN_TL's Avatar
I just asked Martin about just the connectors and you can get the full set for $120.
The connectors are hard to come by since there aren't too many people crazy enough to do this project. I ended up going with unassembled aftermarket connectors for some of the wiring and wasn't happy with the build compared to the genuine versions.
Feb 25, 2020 09:57 AM
BoricuaTL
Apr 8, 2016 01:08 PM
tallyrlx
3G RLX Audio, Bluetooth, Electronics & Navigation
Feb 26, 2016 03:44 PM
travr6
Sep 6, 2015 02:11 PM
MyKids&Cars
Sep 1, 2015 12:53 PM
