Nexus 7
Old Nov 22, 2013 | 12:31 PM
TL Seth's Avatar
Nexus 7
So I know the nexus 7 (1st gen) has been installed in the Tl before.
My question is if I buy the Nexus 7 (2nd gen), will the install be the same?
Old Nov 22, 2013 | 01:41 PM
maharajamd's Avatar
^Yes
Old Nov 22, 2013 | 05:37 PM
EvilVirus's Avatar
Old Nov 22, 2013 | 06:04 PM
guitarplayer16's Avatar
Old Nov 22, 2013 | 06:41 PM
mzilvar's Avatar
Should actually work a little bit better if you put a little extra time into it.
The new N7 has the ability to have an external mic input on the headphone jack, so you should be able to have your audio out and external mic input both on that jack on top of the new N7.
Which means you can get it to function as a handsfree device for making calls if you use something like talkatone or grooveip with it. You'd also have to use google voice though and do call forwarding when you got in your car, but you can set those up with a trigger using tasker. I suppose if your HFL still works that isn't really a concern though.
You'll have to use tasker or something similar to put the N7 to sleep when it's powered off if you want it to quickly wake-up when you get into your car though and Timur's USB-ROM won't work on the new N7.
Old Nov 23, 2013 | 01:06 PM
CrazyNurse's Avatar
Fight On!
Is your system setup this way? I'm interested in this as I want to gut my entire Navi sound system.
Do you know of anyone who has done this to a Navi TL?
Old Nov 23, 2013 | 03:27 PM
mzilvar's Avatar
I have the first version of the N7, so mine is using USB-ROM.
I've been able to get the tablet to place and receive phone calls doing the setup mentioned above, but I haven't been able to get an external microphone to work and the microphone that is inside of the tablet is buried inside of the dash so it picks up a lot of noise. That makes it really impractical for use, I end up being able to hear the distant end just fine through the car's sound system but they can barely hear me, if at all.
Mine is non-nav and I've maintained use of the stock sound system, here's how mine is setup.
I'm about to change out the PIE X3 for the ISHD531 though, the X3 is giving me a bit of a ground loop sometimes when I use the tablet.
Old Feb 18, 2014 | 08:34 PM
JLT12's Avatar
9th Gear
Its not the same install. Very tricky but it can be done, speaking from experience
Old Feb 18, 2014 | 08:37 PM
^so, what did you do?
help us out here.
as your 2nd post, you just cant leave some information and run away.
Old Feb 18, 2014 | 08:48 PM
JLT12's Avatar
9th Gear
The difference is the connectors on the nexus one the headphone jack and mini USB are on a relocatable ribbion . on the nexus two the connectors are fixed on to the mother board via solder. You will have to dremel out the surrounding area (hvac) control buttons. I'll try yo post up pics. Also their an app call Ed keep screen which will you can set to keep your screen on when charging, so no need to root ur nexus or relocate the power button as most nexus 1 installs do.
Old Feb 18, 2014 | 08:49 PM
thanks for expounding, sir!
gnuts
Sep 11, 2015 10:07 AM
C P R
Aug 6, 2011 03:07 PM
goodhed
Aug 5, 2011 08:45 AM
C P R
Jan 17, 2011 11:01 AM
