Need to run power wire HELP
I need some help guys, I need to run 0 gauge power wire cable for my system, Was looking under the hood on Friday in the sunny day light wondering how/or which way i'm going to run the cable.
If you guys have any pictures of which way you ran yours, please share them, Mine is automatic transmission if this helps to anyone....
Pics or simple write up which way you ran your power wire would be very helpful..
Thank You in Advance!
i ran my 4 ga from the pos battery terminal under the fuse box, then under the strut bar, and through the fire wall hole. i have pics but haven't uploaded them to my computer yet. i can put some up tonight or tomorrow, but it's a fairly simple route
Thank You
I ran mine through the stock location, on the driver's side where a lot of the other wires run through the firewall. I had to stretch the rubber a bit to make it fit through, but it worked.
Inside the vehicle, the wire comes down the left side, near the interior fuse box.
There's a 'dummy hole' with a rubber grommet that is not in use. I don't know if it was intended for use, but it's there for the taking with little effort. It's accesible via the driver side footwell, IIRC...
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
