Need Help with Navigation System
Old Dec 17, 2013 | 08:32 PM
AcctCanc11's Avatar
I bought 2006 Acura Tl today with navigation. The navigation was starting withthe acura logo and going to disclamer screen and then back to logo and disclamer. I took the battery terminal off for sometime which reset everything. I entered the codes for radio and nav but now it goes to acquiring signal and back to logo to acquiring signal.
My question is what can I do to fix it?
Is there anyway I could disable the navigation and just use the cd player options on the touchscreen.
Old Dec 18, 2013 | 10:13 AM
AcctCanc11's Avatar
Is there anyway I can just use the touchscreen to access music and everything an just not have navigation features?
Old Dec 18, 2013 | 04:47 PM
Will Y.'s Avatar
Registered but harmless
First, try ejecting the DVD and cleaning the lens with a cleaning DVD.
If that doesn't work, the more radical ways to clean the lens are described in this thread: https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/diy-how-fix-navi-disk-read-errors-873489/.
IDK if you can use the touchscreen audio controls without the Navi working-- try pushing the "Audio" button on the far right of the Navi joystick to see if the audio controls appear. If they appear, you should be able to use them.
Welcome to AZ.
Old Dec 18, 2013 | 05:22 PM
AcctCanc11's Avatar
If that doesn't work, the more radical ways to clean the lens are described in this thread: https://acurazine.com/forums/showthread.php?t=873489.
Welcome to AZ.
Well it started to work but now it just keeps going to disclamer screen and is in a loop. It turns off and then back on to acura logo. I took the dvd cover off and tried cleaning the lens manually but not a luck. It just kept doing it.
Old Dec 18, 2013 | 05:26 PM
MarcoNorthPolo's Avatar
KCCO
As Will Y said, when you press the audio button, does it change the screen or does it just stay in that loop?
Old Dec 18, 2013 | 05:54 PM
AcctCanc11's Avatar
Just tried and it worked! Thanks for that
But is there any way I could solve the navigation? Cd is kind of scratched up but it doesnt give any error for disc error just goes in the loop
What is the latest firmware I need to get for 06 tl
Old Dec 18, 2013 | 07:23 PM
AcctCanc11's Avatar
So after driving a little bit I found out that the navigation disclaimer screen keeps coming back on even after showing the audio. So it plays audio and after a while it will go to the disclaimer and then I have to press audio to go back into the audio screen.
Old Dec 19, 2013 | 10:57 AM
Mr_Cuervo's Avatar
Sounds like the dvd rom is on its way out. Start preparing for next steps. If you want to replace the whole system new, getting yours fixed from Alpine or trying some of the tips to fix from this forum.
Old Dec 19, 2013 | 11:05 AM
AcctCanc11's Avatar
Is the price still $160 something or did it raise like other people said? Do you think it also could be the disc? Is there specific part number for the dvd so I can find it somewhere else. Or can I replace just the lens as someone else suggested in a different forum
Old Dec 19, 2013 | 11:16 AM
Mr_Cuervo's Avatar
No the price for this is $258 from Alpine to be fixed. Keep in mind this is a 30 day turn around time to get your system back after sending to them. Not sure if they include a new disc with your fixed unit but I dont think its your disc. I just replaced my whole unit a week ago for the same symptoms you were having and then ended up getting a black screen. I have some links for DIY fixes from here I will add in a second.
Old Dec 19, 2013 | 12:12 PM
Mr_Cuervo's Avatar
There is no specific part for the disk. I believe you have an orange one. You can use any orange disk and it will work for your system.
This link seems to be something to try as far as the lens https://acurazine.com/forums/showthread.php?t=873489
Alpine info just in case
https://acurazine.com/forums/1g-tsx-problems-fixes-128/help-my-navi-keeps-trying-reboot-677223/
Old Dec 19, 2013 | 03:52 PM
AcctCanc11's Avatar
https://acurazine.com/forums/showthread.php?t=677223
Appreciate the help did you replace the lens or cleaned it?
Old Dec 19, 2013 | 04:02 PM
Mr_Cuervo's Avatar
I replaced my whole unit.
agupta3224
May 23, 2017 08:30 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
