need help installing FM Modulator
Old Feb 21, 2005 | 08:20 PM
TUY3T's Avatar
hmmm...who me?
I've been searching the forum for hours now and can't find a solution. I have an 02 TL Type S w/out Navi. Just bought a kenwood music keg and a FM modulator (not wireless) to use with the factory radio. To get power to the FM modulator i need to connect a red wire to the ignition and a yellow wire to the battery. Where can i find the Ignition wire and the battery wire in the car? First time installing please help.
Old Feb 21, 2005 | 11:54 PM
vidoprof's Avatar
TUY
Hopefully this doesn't come out too harsh sounding cause really I don't mean it like that... but you might find a better answer to your question on the Second Gen Forums. This is the 2004 and 2005 TL forum. They are different cars.
Also you might want to try the Manual for your car I AM SURE that there is a manual out there that has this information in there.
Again dont mean to sound harsh, but this is the wrong forum.
Ryan
Old Feb 22, 2005 | 07:59 AM
TUY3T's Avatar
hmmm...who me?
My bad, thanks for directing me in the right direction.
Old Feb 22, 2005 | 08:20 AM
ludachrisvt's Avatar
Wants an M3 in
well I need instructions on how to take my 3 G dash apart to do this ... I am in the right forum so help me
Old Feb 22, 2005 | 08:30 AM
andym22's Avatar
You dont have to connect directly to the ignition switch. You can tap off the fuse box. Auto zone sells something that you can add an additional fuse so you won't have a problem.
For the red you'll need a fuse that would be switched off when the car is off, I tapped off the airbag fuse.
For the yellow you'll need a fuse that would be live all the time, for this you'll have to talk to a second gen'r to get which fuse to tie into.
Or you can buy a voltmeter and find which one is live all the time when the car is off.
Old Feb 22, 2005 | 11:48 AM
Brewmaster's Avatar
I'm Baaack!
Andy - You tapped off the airbag fuse??!?!
You're a braver man than I .. I'd be afraid that one spike or bad ground out and POOF!!! I'd be looking at the world's biggest kernel of pop-corn coming out of my steering wheel.
I think we have two empty slots on the inside fusebox, have you already used those?? They would've been my first choice.
Old Feb 22, 2005 | 04:45 PM
andym22's Avatar
I did this in my 2000 accord, no problems. Looking back on it I probably should have found another switched ignition source.
the link for the add a circuit is
http://www.partsexpress.com/pe/pshow...number=071-580
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
Rachel Lu
Sep 27, 2015 09:53 AM
Sep 17, 2015 09:01 PM
TxRzrBk
Sep 17, 2015 01:07 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
