Need help to add amp w/o cutting harness
Old Oct 17, 2007 | 01:46 PM
pdphill's Avatar
TX JD
I want to add a Rockford Fosgate 3SIXTY.1 at the amp output so I can add better amps. I realize I can grab the low level signal before it goes into the amp, but on my RDX I have reasons for grabbing the high level signal as it comes out of the amp. I am asking my question on the TL forum because I also have an '04 TL and this forum is much more knowledgable and active than the RDX forum. I do not want to cut the factory wires in order to use the Connector A out of the amp that goes to the speakers and no aftermarket adapter harness is currently available that I could find. What I'm thinking is to remove the existing female terminals and wires from the 18-pin plastic connector, then add new female terminals crimped on the wiring from the 3SIXTY.1. Can anyone provide info on where to buy those terminals? Acura has a Terminal Repari Kit for about $75 (07692 0010000 0252437) but I don't know if it contains the correct terminals for this connector or enough, since I will need 16. I also see that Acura sells individual terminals and connectors and splices but the dealer could provide no help in identifying which part numbers were correct. Anyone have any info or suggestions? Thanks.
Old Oct 18, 2007 | 09:55 AM
rodneyc77's Avatar
Retired!!! ON TOP!!!
nope... sorry...
Most of us just Cut the harness...
Jul 16, 2017 07:33 AM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
polish_pat
Sep 25, 2015 12:24 PM
