Need a groove into console
B A N N E D
I had the iSimple Gateway installed in my '05 TL but need a groove on the edge of the console enclosure for the wire to come out without clamping down on the wire. What would be the best way to do this?
AZ Community Team
Received 7,770 Likes
Center console/storage? There's alread a wire outlet/groove there (at least inthe '07/'08).
Otherwise a picture of where this is installed might help figure best way to cut one.
The 04 to early 06's don't have the wire groove pass-through. I believe the 07/08 TLs groove is on the driver's side of the console.
You can probably use a dremel tool to cut a small groove and glue felt cloth inside the new groove to make it appear like OEM.
two pennies.
two pennies.
two pennies.
two pennies.
![](https://img82.imageshack.us/img82/3241/usaspecinstall4kk7.jpg)
B A N N E D
I think I might just dremel it and see what happens. I'll post pics if it turns out the way I want it to, and if it looks bad I'll just order the one with the groove. Thanks for your help!
mlody
12-04-2019 02:11 PM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
InFaMouSLink
10-27-2015 06:52 PM
