Need electrical wiring help - for reverse cam
Old Jun 12, 2015 | 01:57 PM
guitarplayer16's Avatar
Hey guys,
This is an incredibly noob question, and it's basic wiring - but I need confirmation.
Currently I have my backup camera power (positive and negative) hooked up to the positive and negative of the reverse light wire (driver side).
I would like my camera to be able to turn on by a switch which means I would wire the switch to a "constant on" source.
If I splice into the positive wire of the backup camera, it should work without turning on my reverse lights?
Or do I need to add a diode, and where would I add it?
Maybe I just need to do more researching - I'm sure this has been done a million times lol
Thanks!
Old Jun 12, 2015 | 02:07 PM
polobunny's Avatar
Registered Bunny
You want your camera to turn on at a flick of a switch + automagically when you hit reverse?
Old Jun 12, 2015 | 02:10 PM
Yes sir.
Real simple, right?
I feel embarrassed to even ask.
I've never used diodes before, but I understand how it works now.
I found this picture:
My setup would be the same, except ignore the "Head Unit Reverse detector lead" wire that's drawn (my monitor turns on/off automatically when it receives video signal )
Would you be able to confirm?
EDIT: Now that I know what a diode is good for, which is preventing flow from one direction, I should delete this embarrassing thread, as I KNOW it should work
Old Jun 12, 2015 | 02:29 PM
polobunny's Avatar
Registered Bunny
Sounds just right then.
Terrible picture by the way.
Old Jun 12, 2015 | 03:19 PM
Thanks polobunny.
I picked up the diodes, will be using IN4004. I'm not sure if it's the correct diode, but shock sensor installs use the same so I'm hoping no ill effects.
I'll probably be using two diodes to be safe, one to prevent current flowing to the reverse lights (when my switch is turned on), and one to prevent current flowing to my 12V constant source (to prevent any problems to electric system(?) when my reverse lights are on.
Old Jun 12, 2015 | 03:44 PM
polobunny's Avatar
Registered Bunny
1N4004 is overkill concerning it's 1A 400V blocking. Even the 1N4001 would be fine (1A 50V)
Not that it matters, both are cheap. Forward voltage drop is 1.1V at 400V so probably ~600mV at lower. Shouldn't really bother but something to consider for next projects, some devices can be finicky if they don't get the proper voltage.
Old Jun 12, 2015 | 07:28 PM
Great to know!
Everything works as expected
The switch turns on the camera whenever desired, without turning on the reverse lights, and the reverse camera turns on automatically whenever I reverse.
Old Jun 12, 2015 | 08:07 PM
polobunny's Avatar
Registered Bunny
Great to know!
That was quick haha! Glad you got it working.
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
STC
Sep 23, 2015 04:36 PM
