Need audio expert for advice
my daughter bought a tl 07 type s she is comlaining of her speakers in the rear so i read a lot of your answers on the subject
now i have been a mecanic for over 30 years i know how to plug radios learning on amps sub etc.. not a gourou but i can learn fast modification has litle secret for nohow to fit things
i work in aircraft engines drive a porsche 911 and 944 she choose the acura for wich i know nothing about
So i have in stock new in the box for over a year now
pioneer amp: prs-d2000 spl class d mono 2000 watt continuous power now this thing is 23 inch x 10 inch huge
pioneer amp :prs a-900 4 channels
pioneer amp : gm d7500 m
sub whoofer:pioneer w3001d2/4 in a box sealed x2 12 inch
sub whoofer: momo 12 inch
theise things are doing nothing in the closet WHAT CAN BE DONE ?????? i know i will be needing speakers that is not an issue thanks for your interest in this quest
06 WDP/Ebony MT NAV ASPEC
You have a few options, one is pretty simple. The others more complicated. If she just wants a sub and amp then you have to run wire for the sub, a remote from Fuse 32 or equivalent and you can disconnect the stock sub and use a LOC to change the signal to something the amp can use, unless the amp has line level inputs. (http://www.davidnavone.com/cart.asp?14&pid=212)
A more complicated option is removing the factory amp all together and using a processor and new amplifiers as well as speakers.
I personally used an audiocontrol product and am only amping the sub and the fronts. The rear and center i left off the factory amp.
There are a lot of people on the site that can point you in the right direction once you decide on what you want to do and what kind of budget/time you want to put into it.
soupi
14
11-15-2015 11:15 AM
4drviper
09-23-2015 09:00 PM
