Navtool & Back up camera install pics with notes
Old Mar 21, 2013 | 11:08 PM
supadavesNHBP's Avatar
Thumbs up Navtool & Back up camera install pics with notes
This are the things i used for this project:
*Navtool-awesome seller i offered 190 and they accepted great deal!!
http://www.ebay.com/itm/04-08-Acura-TL-Navigation-Video-Converter-Add-DVD-NAV-TV-Rear-Back-Up-Camera-/280989009053?pt=Motors_Car_Truck_Parts_Accessories&hash=item416c40049d&vxp=mtr
*Water proof camera- works great!!
Amazon.com: Waterproof Car Rear Vehicle Backup View Camera High-definition Cmos 170 Degree Viewing Angle E363: Electronics Amazon.com: Waterproof Car Rear Vehicle Backup View Camera High-definition Cmos 170 Degree Viewing Angle E363: Electronics
*18 gauge wire
*locking quick splice connectors
*electrical tape
*multimeter a MUST!
*common sense
*dremel-must cut the middle piece of the tag holder up top and this tool made it a lot easier and cleaner look.
* drill and bits
camera has:
*video (yellow cable) just run it down to the Navtool and connect to Video 2.
*Power ( red cable) has 2 small wires red for 12v which i spliced into the back up light wire (green wire) which i also used for the navtool reverse +12v and black for ground.
*i made my camera screw holes with a 1/8 bit and got some self-tapping screws worked great
* in order to make the wire fit thru license bulb assembly you will need to cut about 6 inches from the camera and then rejoin the connection.. its cake dont sweat it!!
*i added some velcro between the camera and car to give it a better angle before i tightened down the screws so my camera would not point down so much and i got it perfect i think!!
navtool has:
*red wire (accessory 12+v) this wire goes on the yellow and red wire on the 8 pin white connector behind the navi dvd player (located in the trunk right rear)
*Orange (reverse lights 12+v) goes on the + wire (green wire) of the back up lights harness
*gray (parking brake cable) black (ground) goes on splice on to one of the existing ground on the chassis ( cant miss it it has about 6 ground on it)
* yellow (push button or switch cable) you can run to the center console to switch from video 1 and video 2. (i did not use it but i left it prepped when i receive tvs and dvd player)
MAKE SURE YOU DISCONNECT BATTERY BEFORE SPLICING INTO ANYTHING!!! COMMON SENSE BUT JUST A REMINDER!!!
i was rushing thru it so i missed a lot of pics but i got the important ones or the ones i had doubts about so i hope it helps a lot of yall!! GL
Attached Thumbnails Navtool & Back up camera install pics with notes-20130320_114818-1.jpg   Navtool & Back up camera install pics with notes-20130320_114838-1.jpg   Navtool & Back up camera install pics with notes-20130320_120029-1.jpg   Navtool & Back up camera install pics with notes-20130320_123948-1-1.jpg   Navtool & Back up camera install pics with notes-20130320_180932.jpg
Navtool & Back up camera install pics with notes-20130320_180959.jpg   Navtool & Back up camera install pics with notes-20130320_144709.jpg   Navtool & Back up camera install pics with notes-20130320_150849.jpg   Navtool & Back up camera install pics with notes-20130320_150902.jpg
Old Mar 21, 2013 | 11:11 PM
Attached Thumbnails Navtool & Back up camera install pics with notes-20130320_165218.jpg   Navtool & Back up camera install pics with notes-20130320_165245.jpg   Navtool & Back up camera install pics with notes-20130320_165607.jpg   Navtool & Back up camera install pics with notes-20130320_165612.jpg
Old Mar 22, 2013 | 03:50 PM
Pghpizzaman's Avatar
2004 TL SSM w/NAVI
navtool the ebay seller sucks i DONT recommend anyone to use them!!
7 weeks and countless emails, buyer beware
but your setup looks good. i have the same minus backup cam
Old Mar 22, 2013 | 06:45 PM
I cant say the same the shipping was fast and the navtool works so far!! sucks you had bad experience.
thanks! it was pretty easy for the cam just time consuming and patience!!
how was your Isimple install?? i got to jump on that one soon so tips would be certainly generous sir!!
Old Mar 25, 2013 | 12:16 AM
Grey Gonzalez's Avatar
Bookmarked this page and have added this to the "to-do" list. Awesome write up and thanks!
Old Mar 25, 2013 | 07:16 AM
NP. Lmk if I can help you with something! !
Old Mar 25, 2013 | 11:08 AM
vietkid_2006's Avatar
I bought my Navtool on ebay two weeks ago and it came within the week.
Old Mar 26, 2013 | 08:25 AM
Did you purchase from seller I posted??
Old Mar 26, 2013 | 09:41 AM
philanderer's Avatar
Do you need the navtool for the backup camera to work?
Old Mar 26, 2013 | 10:52 AM
NavTool's Avatar
Former Sponsor
hi, yes you nned the camera to make everything work
Old Mar 26, 2013 | 05:53 PM
Most def and its well worth it my friend!!
Old Mar 26, 2013 | 09:29 PM
AnthraciteAspec's Avatar
RPF1+RS3 FTW
I just installed the same setup as you last weekend. Navtool and the exact same camera. For my camera I did the wire just to the side of the light and put a grommet in there so it seals perfectly with the light back in place.
Here is pic:
I had to do the same thing with the spacer to get the correct angle on the camera.
Nice job man, I love having a cam now.
Old Mar 26, 2013 | 09:49 PM
Awesome man it looks good!! To me is a must have specially if you have tinted windows. for me it was easier making the hole on the license plate light assembly I did add some rtv so it don't leak and it hasn't yet!! Thanks for sharing!!
Old Mar 26, 2013 | 11:05 PM
RPF1+RS3 FTW
Yea my back window is limo tinted I can't see anything lol
Old Aug 22, 2018 | 05:26 PM
Damian Gonzales's Avatar
What year and model is your acura?
Old Dec 15, 2019 | 04:09 AM
Shaheed Garko's Avatar
Bro i have a 2006 Acura RL and i want to know if i can connect the back-up camera to the car without changing the navigation screen.
Old Dec 20, 2020 | 06:15 AM
RaskalG7126's Avatar
9th Gear
Thank you so much for all the pictures. Just got my navtool after 2 1/2 weeks. Christmas eve going to install.
Old Dec 20, 2020 | 07:06 AM
DMZ's Avatar
DMZ
Head a da Family
Got the Navtool and backup camera about 4 or 5 years ago, and have NEVER looked back (No Pun Intended)
Old Dec 23, 2020 | 08:27 PM
9th Gear
Ok. So I just started prepping everything to install.. but maybe I drank way too much and smoked way too much. (I don't smoke or drink)... but for some reason... the wire colors you are taking about does NOT match up with mine.. I have no gray wire, the yellow wire on mines doesn't even have a label on there, I don't have a wire with a label for handbrake.,
so, I've emailed navtool... but no response. So if anyone could help, it would be greatly appreciated. Thanks everyone
Old Jan 7, 2021 | 01:31 PM
THTL's Avatar
I PMed you.
Old Sep 18, 2024 | 10:07 PM
MotoGP's Avatar
4th Gear
I know this is a very old thread... but does anyone still have their NavTool 3.0 or 5.0 manual? I need to know how to turn off the backup camera guide lines. TIA
Old Dec 4, 2024 | 02:11 PM
wlbolton's Avatar
To turn off the parking lines on a NavTool device, locate the "MIRROR" switch inside the unit and set it to the "OFF" position; this switch is typically responsible for toggling the visibility of parking lines on the display.
Key points about the NavTool parking line switch:
  • Switch location: You'll need to access the inside of the NavTool unit to find the switch.
  • Switch name: The relevant switch is usually labeled as "MIRROR".
  • On/Off function: Setting the "MIRROR" switch to "OFF" will disable the parking lines on the screen
Old Dec 5, 2024 | 01:57 PM
MotoGP's Avatar
4th Gear
Thanks for the reply. Unfortunately, the NavTool company did not document their hardware correctly:
- No switches are located within the unit (pls. see photos)
- The “dual dip switches” on the back of the unit, near the gray input harness do nothing
* The dip switches do not seem to do anything.
Old Dec 6, 2024 | 03:14 PM
MotoGP's Avatar
4th Gear
Thanks for the reply. Unfortunately, the NavTool company did not document their hardware versions correctly.
Needless to say, their support team does not answer the phone, nor respond to emails. But their sales team is happy to sell me another unit that “should fix the problem”.
SLIKRIK
1G TSX Photograph Gallery
Mar 4, 2013 09:21 PM
xtremex626
2G TL Photograph Gallery
Oct 27, 2011 02:38 PM
DAYTA
46
Oct 9, 2007 02:14 PM
Dan Martin
Cameras & Photography
18
Aug 2, 2006 02:19 PM
