Navigation problem
Old Sep 25, 2011 | 07:22 PM
sammyj's Avatar
8th Gear
Navigation problem
Is there any way to get a 2007 tl navigation system back to its default settings if neither the touchscreen or toggle switch works.
Old Sep 25, 2011 | 08:42 PM
sddale's Avatar
You could try to disconnect the battery but you'll need the radio and nav codes.
Old Sep 25, 2011 | 09:57 PM
sammyj's Avatar
8th Gear
Thought about that but unless I know for sure it would reset the defaults i wouldn't take the chance because I wouldn't have a way of inputting navi code.
Old Sep 25, 2011 | 10:11 PM
sddale's Avatar
What happened to make the screen unresponsive? If you can't input anything anyway it doesn't really matter if you can't input the code right? You could try to disconnect the screen from the back then reconnect it but you'll have to take the console apart.
Old Sep 25, 2011 | 10:50 PM
sammyj's Avatar
8th Gear
The toggle switch did work but got disabled.That's what I need to get reset.Right now my screen comes up and gets to the OK prompt but I can't get pass this point.I just think there should be some type of media recovery for this type of problem.
Old Sep 25, 2011 | 11:01 PM
sddale's Avatar
Is the radio still hooked up?
Old Sep 26, 2011 | 10:55 AM
sammyj's Avatar
8th Gear
Yes the radio is still hooked up.The only thing that doesn't work is map display. I can still do voice commands (exp: display audio). Unfortunately there isn't a voice command to activate the OK response to get to map display.
Old Sep 26, 2011 | 12:13 PM
sddale's Avatar
It sounds like the screen will probably have to be repaired or replaced. I would try to unplug the battery to see if it resets anything...unless there are some functions you'll lose by not being able to enter the code.
Old Sep 26, 2011 | 06:07 PM
sammyj's Avatar
8th Gear
I was going to replace screen at a later date or when I could find a great deal. It was cracked when I bought car so it never worked for me but the toggle switch worked so I could use navi.Not now though. I don't know what functions I would lose so that is why I haven't done the battery thing. Thought about just disconnecting it at the dvd unit itself too.Anyway thanks for your input and will research this a little longer before I pull the power.
Old Sep 26, 2011 | 08:21 PM
gilla_monster's Avatar
My nav won't work only about 1 in 20 times I start the car (although it hasn't worked the last three times). It is still the original disk, so I think I'll give that a shot first before I go sending my Nav anywhere...
Old Oct 1, 2011 | 02:17 PM
sammyj's Avatar
8th Gear
Thought I would let you know I decided to take a chance and disconnect the battery. I did and got my toggle switch function back. I am now a happy camper. Will keep looking for a good deal on a touchscreen and eventually replace it.
Old Oct 1, 2011 | 02:44 PM
sddale's Avatar
Nice.
BoricuaTL
Apr 8, 2016 01:08 PM
tallyrlx
3G RLX Audio, Bluetooth, Electronics & Navigation
Feb 26, 2016 03:44 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
Gianni Formica
Sep 7, 2015 08:28 PM
travr6
Sep 6, 2015 02:11 PM
