Navigation Code - Entered Wrong Too Many Times
Old May 9, 2009 | 11:51 AM
josephle's Avatar
I have a 2006 Acura TL. I have the correct navigation code for it. I thought I remembered it so I entered a series of numbers without looking at the code card. Now the screen doesn't give me an option to enter a code anymore. I just see the Globe splash screen and then it goes black.
So far, I've pulled out the negative terminal on the battery and let it sit all night. This morning I connected the battery back on and got the same thing.
Help!
Old May 9, 2009 | 11:54 AM
josephle's Avatar
I tried pressing "Cancel" and that didn't work either. Also tried many posts that I read such as holding Map + Cancel or Setup + Cancel. All did not work.
Old May 9, 2009 | 12:50 PM
woot427's Avatar
hmm ...disconnecting the battery works for me if i guess it wrong too many times.
Old May 9, 2009 | 01:26 PM
josephle's Avatar
I've also tried removing all the harness AND the battery.
Old May 9, 2009 | 11:30 PM
fade2blk's Avatar
have you tried to remove dvd from the trunk?
pop the cover open and hit eject. the display should come on prompting you to insert it back in.
Old May 10, 2009 | 03:11 AM
vipernj's Avatar
I just ejected the dvd and re-inserted it and it worked fine
Old May 10, 2009 | 07:45 AM
fade2blk's Avatar
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
Gianni Formica
Sep 7, 2015 08:28 PM
SUPRMN84
Sep 2, 2015 11:50 PM
