Navi - Map Movements - Delay by 2-3 seconds
Old Jul 3, 2007 | 09:02 PM
quanTL's Avatar
Question Navi - Map Movements - Delay by 2-3 seconds
Sorry guys..I've tried a few searches and couldn't find anything.
I have an 04 with Navi.
I just noticed that the movement of the A symbol on the map is kinda slow.
For example, a street intersection would be coming up, on the map.
The I noticed that I actually passed the intersection before the A symbol passes the intersection on the display map. Seems like a delay of 2/3 seconds.
Is this happening to anyone else?
Or is there a way I can correct this thru the Navi setup?
I tried, but couldn't find any settings where I can change this?
its so hard to explain...hope you guys understand what I'm trying to say.
Old Jul 3, 2007 | 09:13 PM
BLACKURA_NY's Avatar
I have car ADD
re-sync.
kill the battery for about 10 minutes, re-hook it up. start the car in an OPEN area and dont move for a few minutes.
Old Jul 3, 2007 | 09:18 PM
quanTL's Avatar
thanks...
Is it just me or any one else experience this?
Will this work for sure?
Any thing else I need to do besides re-hooking the battery? (press any buttons on the nav?)
What is the cause of this not sync?
Old Jul 3, 2007 | 09:24 PM
I have car ADD
nah, when you turn the car back on, it will say something on the screen about being in an open area, and not moving for like 3-4 minutes while it calibrates.
you can use the NAVI function screen, which may have a diagnostic that tells you if you are having a serious problem... im not sure how to access it... you press two buttons at the same time... i think info & cancel or something. not sure which 2. but that will diagnose the hardware
you probably just need to re-sync... think about it, car is 3 years old, and it might have never been recalibrated, as people seldom remove or disconnect their battery
Old Jul 4, 2007 | 01:13 AM
csmeance's Avatar
push the MAP, MENU and CANCEL buttons for 5 seconds. You can go thru the menus for diagnostics and stuff. If you want to have it functioning right, you can either reset the car by pulling the battery or you can do it from the navi. Not sure on how to do it in the navi off the top of my head, but i can find later on today.
Old Jul 7, 2007 | 09:05 AM
quanTL's Avatar
I tried going into the Navi setup screen.
Couldn't find anything that i was willing to tamper with. lol
I didn't want to screw it up.
Old Jul 7, 2007 | 11:37 AM
kenny5's Avatar
Try driving to a major hwy near you that is digitized. This may allow the satellites to reposition your car accurately on the navi map. It worked for me.
Old Jul 10, 2007 | 07:50 PM
quanTL's Avatar
What do you mean by digitized? ?
quanTL's Avatar
i went into the navi set up screen...what is a yaw rate?
4drviper
Apr 23, 2025 07:13 PM
SidhuSaaB
May 30, 2020 12:40 AM
Cgannotti
Sep 25, 2015 05:04 PM
TL14
Sep 24, 2015 04:37 PM
rboller
Sep 23, 2015 02:49 PM
