Navi Hack - AC Control Issue
Old Apr 19, 2011 | 12:31 AM
ilovemangoes's Avatar
Being the lazy student that I am and not studying for my final that is two days away, I decided to spend some time getting the Navi Hack for my TL and after 2 hours......
it worked!!!!
Anyways, my question is, for the AC control on the navi screen, everything works fine except for the 4 modes displayed. I can't change them by pressing them down, and can only change them by pressing the mode button at the side of the navi screen. Is it suppose to work this way? Acting as an indicator of which mode you're in instead of allowing you to change it freely on the navi screen? If I try to press one of them, the button will be pressed down as long as my finger is on it but once I move my finger away, it will just jump back to the original mode without changing anything. So...just wondering if there's some secret technique in changing the mode of air flow on the navi screen or is it functioning properly already?
Thanks in advance.
Old Apr 19, 2011 | 10:57 AM
dwb993's Avatar
It may be a limitation of the system. It is my belief that Acura tried to incorporate a bunch of features into the TL but could not make all of them work with HFL. So, instead of re-writing the entire code, they disabled some features and added the MID. You may also notice that HFL does not work properly if you are on any of the hacked screens (Trip Computer, especially).
Old Apr 19, 2011 | 01:18 PM
Oh Wow, is that so? I didn't check the HFL system to see if it still works, I guess I will go try it out today. I need my HFL
Old Apr 19, 2011 | 08:24 PM
dwb993's Avatar
Yeah, it gets confused. Simple fix is to go back to one of the OEM screens and then use HFL.
Old Apr 20, 2011 | 09:14 PM
THanks! HFL hasn't screwed up on me yet but I guess it's because I'm usually on the map screen and only ocasionally use the trip computer to track my MPG.
mada51589
Jan 9, 2025 04:40 PM
Ol'Dave
Sep 5, 2020 02:56 PM
cycdaniel
Dec 17, 2019 10:58 AM
nuldabz
Sep 3, 2015 05:49 PM
SUPRMN84
Sep 2, 2015 11:50 PM
