Navi Converter
Navi Converter
I took apart my trunk to install Vsokolov navi converter. I don't fell like running the wire all the way to the front fuse box. What can I tap into that is in the trunk area that is powered when I turn the car on.
Registered User
i'm not 100% sure on this, so test this out first since i will not be help responsible for something going wrong.
looks lilke it's Connector C which is the 8 pin wire and the yeellow/red is the ACC wire(pin 2)
does anyone have a helms manual to verify this info. Can I tap into anything other than the navi dvd unit. Im a little scaried tapping into that. Can I tap into any of the lights.
Registered User
the tail lights do not get power unless you are pressing the brake pedal
tapping into the navi wires is just the same as tapping into any other ones. maybe you need to bring it to a radio shop if you are that worried
Registered User
Originally Posted by MichiganRich
*Laughs* rbf.... nice burn... sounds like something my dad would have said
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
