Navi Converter
Old Mar 28, 2005 | 08:16 AM
AcuraTL2k4's Avatar
Navi Converter
I took apart my trunk to install Vsokolov navi converter. I don't fell like running the wire all the way to the front fuse box. What can I tap into that is in the trunk area that is powered when I turn the car on.
Old Mar 28, 2005 | 08:21 AM
rbf351's Avatar
Registered User
there is a wire in one of those 3 harnesses that have power all the time and when you turn on the car, search the forum for the colors
Old Mar 28, 2005 | 09:46 AM
AcuraTL2k4's Avatar
The harness that are plugged into the navi box or other harness.
Old Mar 28, 2005 | 10:41 AM
rbf351's Avatar
Registered User
the ones plugged directly into the navi unit(dvd drive)
Old Mar 28, 2005 | 10:52 AM
rbf351's Avatar
Registered User
i'm not 100% sure on this, so test this out first since i will not be help responsible for something going wrong.
looks lilke it's Connector C which is the 8 pin wire and the yeellow/red is the ACC wire(pin 2)
Old Mar 28, 2005 | 12:26 PM
AcuraTL2k4's Avatar
does anyone have a helms manual to verify this info. Can I tap into anything other than the navi dvd unit. Im a little scaried tapping into that. Can I tap into any of the lights.
Old Mar 28, 2005 | 02:00 PM
rbf351's Avatar
Registered User
the tail lights do not get power unless you are pressing the brake pedal
tapping into the navi wires is just the same as tapping into any other ones. maybe you need to bring it to a radio shop if you are that worried
Old Mar 28, 2005 | 02:09 PM
MichiganRich's Avatar
*Laughs* rbf.... nice burn... sounds like something my dad would have said
Old Mar 28, 2005 | 02:16 PM
AcuraTL2k4's Avatar
I dont mind tapping into the Navi Unit but I need to be sure that I'm tapping into the right wire.
Old Mar 28, 2005 | 02:23 PM
rbf351's Avatar
Registered User
lol, my dad is a mechanic so he would have just done it for me if i'm not sure and yell at me later
Old Mar 29, 2005 | 01:19 AM
1nicetl's Avatar
Turbo kit in the works!!!
Just take it to a audio shop. So if anything does happen they are responsible.
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
lanechanger
Oct 13, 2015 10:56 AM
jmaxima03
Sep 27, 2015 10:22 AM
Cgannotti
Sep 25, 2015 05:04 PM
Dman00tl
2G TL Photograph Gallery
Sep 25, 2015 10:34 AM
