Navi Consistently off 100', Navi Diagnostic Menu
I did a search and checked out the entry noted in the 3G Garage, but didn't find any real answers.
My Navi is pretty consistently 'off' maybe 100' with respect to cross roads. It *might* be off laterally too, but the "snap to road traveled" would mask that.
I tried the 'adjust vehicle location' option in menu option 4 (I think that's the option), but it seems to have mixed results and doesn't seem to 'stick'.
I saw a reference in a thread "your Navi needs to be recalibrated, you can do it if you know how" - of course no explanation of calibration was offered nor a reference.
There were also references to metalic tint mucking up the Navi. There's tint on the rear glass from the previous owner. I have no idea if it's metalic or not - can you tell by examining the tint? However, the Navi does not seem to have any issue locking onto the satellites, so I don't think that's an issue.
And please no "the gov't/military degrades GPS signals for civilians". SA (Selective Availability) has been turned off for years.
Any answers or suggestions?
Also, in the Navi diagnostic menu there's an option for VSP/set pulse count/manual/auto "thingy". I've seen references to the YAW position setting and what it's about, but nothing on VSP. I'm thinking this is related to the vehicle speed and it's relationship to the Navi. Other threads have stated that the Navi uses inertial sensors most of the time instead of calculating position using the GPS signals - this seems really stupid to me. I could see using inertia if the GPS signals were lost (as in a garage)... so I wonder if this is really true.
Does anyone know anything about the VSP setting?
I'm generally disappointed that the Navi is inferior to the $225 Magellan Roadtrip 3100 that I have in my Ford Explorer.
Thanks in advance for any info you can share.
Steve
Steve
VSP Setting Experimentation
Just to follow up on myself - I threw caution to the wind and took the VSP setting out of automatic.
On my car, the VSP setting was "4".
When I set it to "5", the Navi display indicated I was traveling way faster than reality.
When I set it to "3", the Navi display indicated I was traveling way slower than reality.
Looks like 4 is 'correct'.
I still have it in manual mode - for no particular reason than experimentation.
Steve
Steve
The GPS antenna is somewhere inside the car on the rear deck. Hence the warnings about metallic tint.
I have no idea how to help on the other issues. Just wanted to confirm that the GPS antenna is not on the roof.
Navi Location Error Fixed?
I may have fixed this. I used the 'clear memory' function under the diagnostic menu. When I selected this function, the Navi sat there for maybe 15 seconds and then rebooted. I'm not sure what memory was cleared, but I did not lose my "OK button hack".
After the reboot, the current positioning of the car on the map seems much more accurate. Not perfect, but closer than it was.
I have no idea why clearing the memory improved things.
Steve
Steve
Steve
Steve
I was told, but I never looked into it, that the yaw settings, were to help calibrate the VSA. If you are to mess with it to much you might make changes that would caused the car to become unstable in certain conditions. I have watched the screen while driving, stopping and corner. The percentages seem to change with the vehicle. However, I am not 100% sure about this.
MrHeeltoe
20
02-23-2023 01:54 PM
lanechanger
10-13-2015 10:56 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
