navi ?
Old Oct 1, 2004 | 01:37 PM
rescueswimmer's Avatar
navi ?
Have any of you guys had a problem with the voice recognition. Not often but enough I will give the nav a command and the stupid Bi*&h will do something completly diffrent. I'll say it like 5 times and she doesnt listen. Then I'll mess around with the radio or something then ask the same thing and she does it. I didnt change what I said or do anything diffrent. Anybody run into this.
Old Oct 1, 2004 | 02:14 PM
Brewmaster's Avatar
I'm Baaack!
Usually my problem is that I'm in the wrong menu or trying to give commands in the wrong sequence. (My fault)
If I can get it right, and the windows/sunroof are closed it goes pretty well.
Old Oct 1, 2004 | 08:09 PM
92NSX's Avatar
I have noticed the same type of problem. It must either be the way I pronounce my words, give wrong command for current menu, or wind/road noise is interfering with my voice.
Old Oct 3, 2004 | 11:02 PM
hodge's Avatar
Try saying Navigation Help to make sure you are giving the commands in the propper format - Also only push the button and then let go - you do not need to hold it while you speak. It works better without the fan on high speed.
Old Oct 3, 2004 | 11:38 PM
JoganJani's Avatar
never stops!
I get it 99% of the time right and I do have a very hard accent. The trick is slow and monotonous.
Old Oct 4, 2004 | 11:42 AM
I'll try it slow and see what happens. I do not hold the button in. I was reading you may have to be on the appropriate screen for the voice commands to work. What exactly are they talking about. My main problems are when I try to use the a/c commands.
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
lanechanger
Oct 13, 2015 10:56 AM
us285126
Oct 2, 2015 02:03 PM
jmaxima03
Sep 27, 2015 10:22 AM
Cgannotti
Sep 25, 2015 05:04 PM
