My Secret Media Player REVEALED - Mediagate MG-25P
Old 08-29-2006, 10:32 PM
  #361
OMGWTF4THGENTL
Kennedy's Avatar
Originally Posted by Malayalee King
Couldn't you just snip away some of the plastic on the plug to expose more of the contacts instead of stuffing something inside the player?
I say this because I have an iRiver mp3cd player and I lost my wall charger. The wall adapter that came with the mg-25p fit but didnt go all the way in. I ended up snipping some of it away with a wire cutter. Lo-n-behold I have a charger for my mp3cd player
no can do. you're stuffing wire inside the plug charger tip, NOT inside the player. The charger plug is too deep, the wire fills up the plug a bit so the inner "hole" portion will make contact with the male portion of the player receptacle.
the yellow plastic tip isolates the inner + from the outer -...
If you have the adapter, and look at it, you'll understand the directions I'm trying to provide.
Old 08-30-2006, 12:26 AM
  #362
brianp6621's Avatar
Originally Posted by datmrman
To use the component RCA cable as an extra RCA for the MG-25, use this mapping:
Blue => Yellow
Green => White
Red => Red
This is how I have it connected in my room. It works like a charm.
Yep, figured it out tonight. Thanks!
Old 09-01-2006, 11:58 AM
  #363
jdeec's Avatar
I think someone said they have the MG-35 and is using it in their car. I'm wondering how you power the unit as the plug is a bit different than the MG-25?
This is not really a good shot, but the PWR plug has 4 pins(it seems to be the same on all my other 3.5" hard drive enclosures.
Old 09-01-2006, 12:20 PM
  #364
datmrman's Avatar
Riiight.. sorry about that.
The MG-35 uses a power adapter similar to laptops. I guess you will have to look for a compatible car adapter. The easy route is just to use a power inverter and plug the power adapter into that.
Old 09-01-2006, 12:28 PM
  #365
jdeec's Avatar
That's what I was thinking, using the power inverter. Would it be ok to use the cigarette lighter for both Dom's unit and the power inverter? Crap I almost forgot about the USA spec adapter I will be using, how/where will I power that?
Old 09-01-2006, 12:52 PM
  #366
brianp6621's Avatar
USASpec needs no power.
Old 09-05-2006, 07:41 AM
  #367
mcowher's Avatar
I've made some progress on getting ahold of a "Car Kit" for the MG-35...Still looking for one specifically for the MG-35, but it looks like several other media devices use the same 4-pin power plug and also the same infrared extender cable...
Here are some links for the car power adapter for the Modix HD-3510, which appears to use the same plug:
Photo of Car Adapter
Back of HD-3510
Ordering Link
Old 09-07-2006, 05:29 PM
  #368
jdeec's Avatar
bump for response
Old 09-07-2006, 06:00 PM
  #369
Trucki!!
lembowski's Avatar
bump for response
Why not? I am
Old 09-08-2006, 07:54 AM
  #370
mcowher's Avatar
bump for response
You don't want to try the car power adapter option?
I ordered one of these on 9/5/2006, and I'll let you know if it works with the MG-35.
Old 09-08-2006, 08:12 AM
  #371
mcowher's Avatar
Power inverters generate a lot of heat, can be very noisy and usually introduce "hum" into the audio output of the device they are powering.
Old 09-08-2006, 09:23 AM
  #372
Trucki!!
lembowski's Avatar
I have a 60watt small inverter from radioshack that is not too much bigger that the plug on that one . It works well and doesn't get really hot........and certainly doesn't hum.
Old 09-08-2006, 12:39 PM
  #373
datmrman's Avatar
The Mediagate MG-25 requires 5V at 2 A, which means 10 W (Power = Voltage x Current). Lembowski's 60 W inverter is more than enough to power it.
Old 09-08-2006, 02:01 PM
  #374
jdeec's Avatar
out of stock, you must have ordered the last one . I'd be interested to see how that adapter works out, but the power inverter I bought from Radio Shack was the same price, so...
Old 09-08-2006, 04:12 PM
  #375
mcowher's Avatar
Actually, I think JDeec is powering the MG-35, so the power requirements are slightly different.
JDeec, I'll let you know how I make out...
Old 09-08-2006, 05:12 PM
  #376
datmrman's Avatar
From the AL Tech website, the MG-35 uses DC 5V / 1.5A, 12V / 1.5A so 12V at 1.5A is only 18W.
Old 09-08-2006, 05:33 PM
  #377
thescoundrel's Avatar
quick question for you guys. Does the MG software allow for playlists that can be saved? I have a grip of mvs and don't want to sort by genre folder...I like ipod video playlist but hate to convert all my files to m4p format.
Old 09-08-2006, 06:37 PM
  #378
jdeec's Avatar
on the al tech unit(mg-35) you can create a playlist but it is deleted upon reboot of the device.
Old 09-08-2006, 09:11 PM
  #379
WDP Director of R & D
KJSmitty's Avatar
Confusing here,,,,
The website specs are definitely weird... How could it be both 5V and/or 12V - both mentioned as DC voltage??
Old 09-08-2006, 10:45 PM
  #380
datmrman's Avatar
I just took a look at the back of my MG-35 and power adapter and it does indeed use DC 5V and DC 12 V.
I'm taking a guess here, but when the MG-35 is connected to the computer via USB, it only requires 5V/1.5A, but when it operating as a media player, it requires 12V/1.5A.
Old 09-09-2006, 08:39 PM
  #381
KJSmitty's Avatar
That would definitely make the car install easier......
Old 09-10-2006, 02:32 PM
  #382
mcowher's Avatar
Well, I got the car adapter for the HD-3510, and it works beautifully with the MG-35. Also, there was a huge difference in using a power inverter and the 110V power supply, versus the car adapter.
With the inverter, as I expected, there were wavy, rolling lines on the video output. With the car adapter, there are none of these wavy lines.
Inverters are notoriously known for creating "noise" in both audio and video devices, and this has been proven to me once again. The video interference with the use of an inverter is unacceptable (to me at least).
Old 09-11-2006, 03:08 AM
  #383
datmrman's Avatar
Very true. Didn't think about that.
It is only easier if you can find the laptop-like plug that fits into the MG-35. Then just create a power cable that taps into the car somewhere.
Old 09-11-2006, 10:13 AM
  #384
mcowher's Avatar
Keep in mind that in automobile applications, the 12V power leads usually deliver closer to 13.8V, so you need to be careful tapping directly into your car power leads to make some sort of home-made adapter with a 4-pin plug if you find just the plug somewhere on the net.
Also, during startup and cranking, the voltages can swing wildly if there is no voltage regulation device present between the car power and your electronics device. Most internal car electronics (like your car radio) have built-in power regulation to deal with the wide range of voltages.
Discussion About Car Voltage Spiking
I'll use a voltmeter on the output pins of the HD-3510 car adapter tonight to double check the voltage levels of the pins, but I'm gonna guess that the adapter is regulating the voltage to a more stable 12V.
Just be careful....Wouldn't want to see you fry your MG-35...
Old 09-11-2006, 01:10 PM
  #385
jdeec's Avatar
interesting. Well I finally put everything together(kind of a pain) and it works as expected. I just need to get a different switch and find a place to mount it. I may consider that HD-3510 car adapter so I can reduce some of the cable clutter under the passengers seat , mcowher how long is the cord?
Old 09-11-2006, 06:19 PM
  #386
mcowher's Avatar
It's a "coiled" type cord like most cell phone adapters, so coiled up, it's about 9-12"...
I'll measure the voltages on the adapter tonight (after I cut the grass... )
Old 09-11-2006, 08:09 PM
  #387
mcowher's Avatar
Measured the voltages on the pins of the HD-3510 Car Adapter tonight, and they are 12.6V and 5.6V...
Also, the cord is about 2-1/2 feet if layed out flat and straight.
Old 09-13-2006, 05:43 PM
  #388
3rd Gear
Pigtaru's Avatar
Sorry for the noob comment, but the player has audio and video inputs....I know that the PIE X3 gives you the aux inputs for audio, where does the yellow video plug into?
Old 09-13-2006, 05:48 PM
  #389
jdeec's Avatar
you need a video converter, the most common on these boards is Dom's TVandNav2Go module, which plugs into the factory nav harness and gives you a video input.
Old 09-13-2006, 06:38 PM
  #390
datmrman's Avatar
Pigtaru, welcome to the boards!
Before you ask, here is the latest group buy thread:
$125 TVandNav2Go's Aug Navi to Video Conversion $125 ENDS Oct 11
Old 09-14-2006, 12:07 PM
  #391
3rd Gear
Pigtaru's Avatar
Thanks datmrman.
I am a new owner of a 2006 TL. I'm anxious to get some mp3 in the thing, and might as well install the TVandNav module while i'm at it. I'm a novice with the TL, but I'm confident I can pull it off. Would you happen to know where I can get good information on how to take apart the TL correctly. I would be interested in something that shows how to take apart the trunk area to install teh Dom and the center console to extract the factory deck to inspect behind it. ^_^ Thanks.
Old 09-14-2006, 12:12 PM
  #392
Trucki!!
lembowski's Avatar
Thanks datmrman.
https://acurazine.com/forums/showthr...hlight=install
Old 09-14-2006, 01:34 PM
  #393
datmrman's Avatar
Thanks lembowski for the link.
Pigtaru, please use the search feature for additional info if needed.
Old 09-16-2006, 08:02 AM
  #394
mcowher's Avatar
FYI...The car adapters are back in stock...
Old 09-20-2006, 11:03 AM
  #395
sunnyflava99's Avatar
When you figure out where to mount it, take some pics
Old 09-21-2006, 01:16 PM
  #396
mcowher's Avatar
FYI guys....I'm working on implementing a simple circuit that will turn the media player ON after it begins receiving power from it's power supply. That way, I don't have to worry about turning it on, and it'll be ready to go.
I'll be modeling it after one of the following two solutions, but I don't know which one yet:
Auto-On Switch Method 1
Auto-On Switch Method 2
Old 09-21-2006, 01:21 PM
  #397
datmrman's Avatar
Sweeet! Please keep us updated!
Old 09-21-2006, 03:39 PM
  #398
jdeec's Avatar
interesting, but I don't turn on my media player everytime I drive, e.g. driving to work(6 miles) or running errands around town. Still seems like a good idea.
Old 09-21-2006, 04:27 PM
  #399
datmrman's Avatar
I think I would be more interested in an auto OFF for the media player. Once the player detects no power, it will safely turn off. That might be difficult though.
Old 09-22-2006, 12:15 PM
  #400
I apologize if this has already been mentioned, but can the video from an ipod be displayed on the nav screen with the use of dom's unit? With the current 80gb ipod going for $349, I might just bite and buy an ipod, something I promised I would never do.
Quick Reply: My Secret Media Player REVEALED - Mediagate MG-25P
