"my custom audio system upgrade w/ 3sixty!"
Old 08-04-2006, 05:42 PM
  #41
Bone stock tl-s
jptl04's Avatar
Originally Posted by ussi
Dude seriously AWESOME setup. I really like the look of your car. The system is just fucking BADASS. major major props on the system i'd pay you to set up my car like that..
I love the wheels... i was soooo close to getting those mayas... they look sick on your car.
i like how u cleared on the side light on the front also Did u do it yourself?
thanks for the props man, those wheels put a nice dent in my wallet, but once i saw them i knew i had to have them. i cleared the sidemarkers myself thanks to the help in the tl garage. it was pretty simple.
Old 08-07-2006, 03:17 PM
  #42
sunnyflava99's Avatar
which audio converter (blitzsafe or PIE X-3) did you use?
Old 08-08-2006, 12:01 AM
  #43
Loose Cannon
lcstyle's Avatar
Originally Posted by jptl04
the ride
Freaking SWEET man!
Oh yeah the Entire Audio system is awesome. You did a great job man, i've seen shit installs from supposedly pro-installers. Like the old adage goes "if you want something done right, you have to do it yourself"
Late!
Old 08-08-2006, 12:43 AM
  #44
'06 NBP TL 6spd
realfresh's Avatar
WOW jpt. Yowzers?
That's one of the sickest installs i've ever seen. Kudos to all your time and effort. How'd you even venture to do all that yourself? Have you built systems before (sure looks like it)?
Btw, how wide are the mayas and what size are the tires? Is there any rubbing? Are you on stock suspension?
Sorry for the uber long post, your car is BANANAS
Old 08-08-2006, 09:49 AM
  #45
CaryTL's Avatar
Originally Posted by zax123
The 12V wire from the DVD unit... it's on whenever the ignition is at ON (II) right? I was looking more for a wire that's 12V only when the head unit is on.
since HFL and navi use center speaker, the remote_on signal is always high even HU is turned off (HFL and navi still work with HU off), but HU sends amp_mute to amp to turn off other channels.
you could make a realy to turn off some amps except the one for center if you want... although the amp_mute signal is very weak and you may need to amplify it with a transistor or something to be able to switch a relay... It can't switch my high sensitivity 5V 313 Ohm relay.
Old 08-08-2006, 09:56 AM
  #46
ഥഎണഡഏ Fellas Inc.
Malayalee King's Avatar
nicely done!
Old 08-08-2006, 10:34 AM
  #47
Team Anthracite Member
zax123's Avatar
Well, I just installed the JL 500/1 into my system (the small Boston GT22 I was using sucked for sub). I realized that the 500/1 has a auto-turn on signal-sensing feature which will look for signal at the input and turn on automatically. It also then outputs 12V at the trigger wire terminal which can in-turn turn on other amps. I am going to try that. That would be a perfect remote trigger. Don't need to run anything from the head unit or amp.
I also realized I had one of these (TR-4) lying around. This can also grab signal from one of the speaker outputs and create a 12V trigger for an amp (or amps). I will likely use this since after I install the 3sixty, I'll need a trigger for the 3sixty itself.
Just following up on the 12V trigger thing... :P
Old 08-08-2006, 11:06 AM
  #48
Bone stock tl-s
jptl04's Avatar
Originally Posted by realfresh
WOW jpt. Yowzers?
thanks again guys for the compliments! this is actualy my third system build, i did another one for my 97'integra gsr before, but nothing, like this before.
mayas are 8.5 wide tires are 245/35/19 there's no rubbing, i have the a-spec suspension
Old 08-08-2006, 04:17 PM
  #49
rctorre's Avatar
do u think the 3sixty is better than the JL cleansweep i was thinkin of puttin the cleansweep in my car and do all the speakers through that....what do u think
Old 08-09-2006, 06:32 AM
  #50
zax123's Avatar
The advantage with the 3sixty is that is has both a subwoofer and center channel input. Therefore all 6 channels in the TL are taken care of. With the Cleansweep, it has only 4-channels so your center and sub aren't taken care of.
Old 08-09-2006, 05:54 PM
  #51
rctorre's Avatar
in ur opinion do u think the 3sixty is better than the cleansweep..btw thanks for the help i have a 10 w7 highout put and i wanna do a whole system but i wanna have clear sound and i need a good processor....
Old 08-09-2006, 11:04 PM
  #52
Bone stock tl-s
jptl04's Avatar
yes! it is better, like zax123 said all 6 chanels will be taken care of and given a good clean signal. the clean sweep only gives you 4 channels not good in a 5.1 audio system. the 3sixty is a good processor, it will give your amps a really good clean clear signal.
Old 08-09-2006, 11:52 PM
  #53
babi_boi_31's Avatar
wow....
you must be electro-technician..
i can NEVER do that..
btw, do you have thread or instructions about your moniter in the visors?
kinda curious..
Old 08-10-2006, 06:22 AM
  #54
zax123's Avatar
babi_boi,
I have some pictures and instructions at my homepage: http://www.robertcotran.com/persephone. Check it out.
Old 08-10-2006, 06:32 PM
  #55
rctorre's Avatar
would u ever consider building the set up that is in ur car for someone else.... just the box that fires into the car?
Old 08-10-2006, 08:00 PM
  #56
morgan040's Avatar
I would definatly pay for one!!
Old 08-12-2006, 12:20 PM
  #57
Bone stock tl-s
jptl04's Avatar
come on it's not that hard, just build a box w/ the right angle. the mirrored sides and the 3/4" plexi were pre cut by a plastics supply store just give them the correct dimensions. use liquid nails (adheasive) to glue the mirrored plexi to the inside. use 3/4 rubber weather strip between the wood and the plexi glass, for an air tight seal. drill the plexi and screw down carefully. really not that hard, just takes alittle skill
Old 08-15-2006, 03:55 PM
  #58
rctorre's Avatar
do u thnk the speakers u have are better than focals....i mean im piecing my system 2gether right now i have a 10 w7 high output with a 500/1 i need 2 find food speakers for my car.....i want insane highs for techno....i need help and btw i LOVE YOUR SYSTEM and how u have the sub's air coming into the car not facing the back....amazing...flawless
Old 08-16-2006, 05:34 AM
  #59
Jaa99pa's Avatar
Hey, very nice system and install. I'm currently working on mine and had a question regarding the Dynamat on the doors. Did you remove the factory white plastic, or did you apply the Dynamat directly over it?
Old 08-16-2006, 12:53 PM
  #60
Bone stock tl-s
jptl04's Avatar
yes, i removed the plastic, you should too if you want the dynamat to work. just cut out small slits for the wire harnesses, and the door handle screw, and don't cover any of the holes used by the plastic clips that are on the door panel.
Old 08-16-2006, 01:43 PM
  #61
Bone stock tl-s
jptl04's Avatar
i don't know if they're better but they are crazy loud! w/ eardrum shattering highs! they're they are rated at 170 max watts. im giving them the right amount of power w/ the jl 450/4. cost was around $350. im sure focals are good too but anything in that price range will give you the highs you want. just make sure you're giving them the power they need.
Old 08-17-2006, 03:20 PM
  #62
rctorre's Avatar
yea im thinkin about gettin the alpine digital theatre amp with 6 channels
Old 08-24-2006, 11:53 AM
  #63
rctorre's Avatar
do u think it would b possible to take a picture of ur amp setup and the underboard where they r held together it would be great if you could.....
Old 08-24-2006, 12:24 PM
  #64
morgan040's Avatar
How did you mount the front of the speaker box to the back of the backseat or did you? I see that new board you put inbetween the seat and the trunk but how did you mount the speaker box to that? I am assuming you sealed off any air from the sub getting into the trunk....right.
This set up rocks!!!
Old 08-24-2006, 12:35 PM
  #65
Bone stock tl-s
jptl04's Avatar
in that same pic you see the board, you can also see that the floor is wood also. i made a seperate floor so everything would ne level. i screwed the box down to that using some brackets.
i'll post some pics later of it uncovered, so you see what i mean.
Old 08-24-2006, 02:19 PM
  #66
Bone stock tl-s
jptl04's Avatar
here you go. they are mounted in a slight angle.
amp rack
all put back together.
Old 09-15-2006, 04:55 PM
  #67
ufmike316's Avatar
how did you remove the door to the trunk from the arm rest? I too have a JL W6v2 playing into the cabin through the arm rest, but can not figure out how to remove the door.
Old 09-16-2006, 09:58 AM
  #68
Bone stock tl-s
jptl04's Avatar
on the back side of the ski pass or rear seat (trunk) there is two scews holding the panel in place. remove the screws on the bottom, then you can take the whole thing out . if you look at the side of the panel, you'll see a long metal pin holding the door on, remove that pin then put the panel back. that's it! i didn't put it back, i wanted a bigger opening for my speaker to fire into the cabin.
Old 09-17-2006, 04:23 PM
  #69
LittleCarp04's Avatar
Where did you get the 3sixty? How much did that cost you? I also want a 3sixty, and was wondering, can you still use all the standard functions, like the handsfree, nav w/ voice and all that? does it auto-mute them still? or have to manually turn it down? And can you still use the standard volume control from teh HU instead of the master from teh 3sixty? And lastly, it does include the software to tune w/ your palm right?
Old 09-17-2006, 06:56 PM
  #70
Bone stock tl-s
jptl04's Avatar
i got it from brandnamez.com for $230 shipped, all the oem functions are all retained. everything works like normal. yes you can still use the standard volume control from hu or steering wheel, all the software is included w/ the 3sixty.
Old 11-21-2006, 07:27 PM
  #71
5th Gear
rlaguirre7's Avatar
where the amps are, what did you use to make the wood on the bottem look gray?
Old 11-21-2006, 11:14 PM
  #72
nguyen220's Avatar
7" nesa monitors in the visors
you cant tell in the pic but the picture quality is really good on these
Hey nice setup. Its been awhile since i've been in the audio scene and just by looking at all these mods and installs your basically pulling me back in . I checked out your site in regards to babi_boi's question but it doesn't show anything for the visors? Do you have any pictures for your install on the visors. Also how di you get the DVD player into the center arm rest in the back so clean. Im very impressed
Old 11-21-2006, 11:28 PM
  #73
mrchan625's Avatar
damn man thats a nice ass install help me with mine ?
Old 11-22-2006, 12:10 AM
  #74
nguyen220's Avatar
The wood works is the easy part it's the lcd in the visor and headrest which scares me. you can't fix that if you mess up you can only rebuy to retry and possibly mess up agian
Old 11-22-2006, 12:21 AM
  #75
Randy is the Future
nore03's Avatar
damn that shit is SICK
Old 11-22-2006, 02:24 PM
  #76
Bone stock tl-s
jptl04's Avatar
i first sparyed it w/ gray primer then used this stuff, looks really good
Old 11-22-2006, 06:48 PM
  #77
5th Gear
rlaguirre7's Avatar
I just got me tl and I want to be able to play dvds in it but I have no clue what I have to buy to get it to happen, so I saw that you had dvd and I was wondering if you could tell me what I have to do in order for this to be possible. Thanks
Old 11-22-2006, 07:14 PM
  #78
Read Matt. 24 3-14
supaman8118's Avatar
lol when I saw 3sixty I thought you were talking about...xbox but anyway the setup is awesome. I've been wanting to put a speaker behind the armrest like that but not as complex as yours, thats a serious setup.
Old 12-01-2006, 01:25 PM
  #79
GO NOLES!
stangd1909's Avatar
That is one nice install! You did an outstanding job man....very clean looking!
Old 12-01-2006, 02:27 PM
  #80
Ryan Christopher
Black_05_TL_6SP's Avatar
This is the box I have currently in the TL. I am thinking of going to a sigle 12"
This was the custom box I had in the back of my Prelude.
Just wanted to add to the pictures.
Sweet set up and I like the new pics with the Type-S tails. I am waiting on the Tails right now. Darn snow storm slowed the delivery down. How do you like the 3sixty? I am thinking about going with it as well.
Quick Reply: "my custom audio system upgrade w/ 3sixty!"
