Multiple Electrical Issues, No Memory, no lights no power unless car is on
so today i was working on my side skirts when i went to turn the car on, i noticed that the hvac system was on and the buttons weren't working. At first the radio was working but then later on it stopped and the security light would come on. The lights on the radio actually do work ONLY when i turn the car on not when i switch it to parking light or headlights on when the car is not on. The car has no problem starting but it has no memory, no power locks, trunk wont work and the whole car is basically dead unless i turn the car on and everything functions as normal besides nav buttons and the A/C wont shut off so i pulled off the fuses from the hood fuse box and it won't turn on. ive checked all the fuses i can related to these issues and they all work. i even took the battery off for about 5 minutes and nothing works. my battery might be a shitty but it does start the car.
i've searched and read alot but nobody has had the same issues i have just some combinations.
any suggestions?
THANKS!
any suggestions?
THANKS!
cipher9878 (12-20-2014)
the only thing I can think of that is common to that many components is the MICU which is in the driver's side fuse box
was anything else done to this car before this started happening or did this just randomly pop up? odd because there is no wiring near the side skirts, I'm assuming you're referring to the exterior A-SPEC or stock side skirts? not even working inside the car at all with that
wusty23jd
09-24-2015 11:41 AM
