Motorola V551 Problem...please help
Old Dec 16, 2004 | 10:27 AM
acuraddict's Avatar
Once in a while when I voice dial a phone number the HFL begins dialing and then hangs up immediately. Then the MID simply says "in use". I can try redialing several times and it will just repeat the same hang up - "in use" process. If I then dial the number with my phone and say "transfer", the HFL will maintain the call.
1. Has anyone else had this problem with this or any other Moto phone?
2. Does anyone technically minded have a suggestion to resolve this?
Thanks!
Old Dec 16, 2004 | 12:21 PM
TLS-Fiend's Avatar
acuraddict,
My V551 has done something similiar but the "In Use" does not stay lit on the HFL display. I have found that if I dial a number by voice and that number is busy the phone just simply hangs up using the HFL. I rarely ever hear the busy signal tone. I am not sure why this happens with this particular MOTO as my T637 never did this with the HFL. I had to force a hang up if the number was busy on my T637 used with the HFL. Anyway, something you may try as a test to see if the number you are dialing is busy when this disconnect occurs.
Old Dec 19, 2004 | 02:52 PM
acuraddict's Avatar
bump...
nobody has any suggestions? all you techie freaks out there, and no ideas???
come on...
ivegotthenav
Sep 11, 2015 07:51 PM
icy CL
Dec 17, 2003 10:40 AM
kevin79925
Oct 4, 2003 05:56 AM
synth19
Jun 20, 2003 11:41 PM
