Mirror Mount Radar - 2008 TL
Old Apr 8, 2012 | 02:01 PM
SoonerChris's Avatar
Anyone try the Rogue Mount found here on a 2008 TL? I know the BlendMount will fit but the Rogue is about $30 less.
http://rogueradarmount.com/
Old Apr 8, 2012 | 08:08 PM
Nrp603's Avatar
Is that ethernet looking thing the power source? looks sweet though! i would get if i had an escort
Old Apr 8, 2012 | 08:50 PM
vietxquangstah's Avatar
I don't think you can tap into the back of our mirrors to get a power source. Back when I was trying to figure out how to hard wire my valentine I thought about using the back of my mirror to tap as a power source but there's no wires that you can simply unplug to insert wires to power your radar detector..
I also have a 2008 TL. I ended up just hard wiring it to the fuse box by the kick panels on the drivers side.
Old Apr 8, 2012 | 08:54 PM
If you find out a way to tap into the mirror, you can just purchase this instead and using suction cups to mount the radar detector to the windshield..
$10 shipped
http://www.ebay.com/itm/280269445867...84.m1497.l2649
Old Apr 9, 2012 | 01:11 AM
dano4o8's Avatar
i have mine hardwired up where the moonroof controlls are
Old Apr 9, 2012 | 01:18 AM
luder917's Avatar
SSM FTW
I hardwired mine to where the moon roof controls are too. Also made my own power cord out of an old telephone cord I found around the house.
Old Apr 9, 2012 | 10:53 AM
jda123's Avatar
Dogmatic Dinosaur
I like mine on the windshield all the way to the right, so I used clear silicone between the cups and the glass. Been fine for a year. $4 perm solution. Hardwiring is a must. You can tap into the overhead console, or if you want to have a remote mute button, you can use a add-a-fuse on fuse $32 and put the button anywhere you want.
Old Apr 9, 2012 | 01:49 PM
sockr1's Avatar
intersted if anyone has experience with the rogue mount also!
my beltronics is hardwired but mounted with suction cups to the left of the mirror and the mirror mount would be a nice permanent fix
Old May 13, 2012 | 05:13 PM
lazyboykhoa's Avatar
i got mine mounted in the upper left corner of the windshield held up with suction cups(based from the inside). my power source comes from the outlet in the center console
Old May 14, 2012 | 11:43 PM
aj_06_TL's Avatar
XDM
Anyone know what the diameter size is 7/8 or 3/4?? Really would like the mount. My V1 is just suctioned to the windshield in the same spot the mount would go but would be soooo glad to get rid of that cord running right through my navi screen!!!!
08KBP_VA
Oct 22, 2019 01:55 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
