Messed up my sub :(
Old Aug 28, 2009 | 07:29 PM
heyeah's Avatar
Messed up my sub :(
So I just finished my install a week ago and got everything tuned up when I decided to order up a grill to protect my sub... Arrived today and while installing it my screwdriver slipped and went through the surround. I have it in a sealed inclosure I fiberglassed.
I figure I'm SOL and the subs toast... but just thought I'd ask if anyone knows of a way to fix.
Old Aug 28, 2009 | 07:59 PM
HEAVY_RL's Avatar
If its just a tear its not toast, you can fix it with clear nail polish or crazy glue.
It wont look perfect but will perform just fine.
DO NOT USE SILICONE...
Old Aug 29, 2009 | 07:44 AM
TLinVA's Avatar
Even if the hole is big, you're still fine. Order a New Foam kit (http://newfoam.com/kits.asp) and fix it yourself! I did this to a pair of 15 year old JBL home speakers with crumbling foam surrounds a month ago and now they sound like new. It's much easier to do than you'd think!!
Old Aug 29, 2009 | 09:01 AM
Adobeman's Avatar
The DVD-A Script Guy
+1 (except for the Silicone warning) fix it with minimal adhesive and move on. If you "blow out" the repair then think about a new foam surround, assuming the OE is in fact foam. As far as silicone goes that all depends. It could attack some materials in the driver or it may not. I've used it to fix small tears in foam surrounds by lightly smearing a very thin layer over the back and front of the tear. A very little bit is all that's required. Given it's a sub in a sealed box it's likely you will blow out a repair eventually.
The new foam surround is a good repair for a surround that's totally shot but is way beyond what I'd try first. Removing the old surround and dust cap, shimming the VC and reinstalling a new surround and dust cap is overkill here. The new surround and dust cap will probably alter the Thiele-Small (TS) parameters far more than a simple surround repair. A sealed system will suffer less from this change than vented but if you did consider TS parameters (I hope you did) then less change to the driver is better in your [unfortunate] case.
Old Aug 29, 2009 | 11:12 AM
rockyfeller's Avatar
King of NYC
I have almost done the same thing as you many times and it's been something I always feared could happen. Sorry to hear about it. It's just the surround, the world is not over. It's just involved mechanically/physically so you can easily fix it. The area near the voice-coils and magnets are the actual "motor" of the speaker, as long as that works you're still in business.
Old Aug 30, 2009 | 08:20 PM
heyeah's Avatar
Thanks everyone for the info. I tried a drop of super glue. Seems to be holding for now.
The sub is an A/D/S that is a few years old. Here I was hoping this was my opportunity to convince my wife that I need to buy a new toy.
Old Aug 30, 2009 | 10:39 PM
I hate cars's Avatar
Wow, I wish I would've known about the refoam kits. I threw my oldschool '91 Cerwin Vegas away. Loved how the old stuff sounded.
emailnatec
29
Sep 28, 2018 04:27 PM
eastcoastguy
Oct 29, 2015 03:00 PM
thegipper
Sep 28, 2015 01:01 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
DwDrummer
5G TLX Problems & Fixes
Sep 14, 2015 08:20 PM
